Neutral Position Switch for M/T
Old Nov 5, 2003 | 11:16 AM
Brian98SE's Avatar
Okay, I admit it. I'm one of the apparently car-challenged folks who managed to break the neutral position switch while changing my transmission fluid. <sheepish grin>
I've got a new one all ready to go but I'm having some trouble getting the old one out. Everything is ready to be pulled off but I cannot for the life of me get the electrical harness connector for the old switch free. It's apparently clipped to a bracket on the transmission. I worked at it for about 45 minutes last night trying to unclip it with no success.
Has anyone actually gotten this thing unclipped? Or am I going to have to <shudder> loosen the bolt on the tranny holding the clip to get the clip off to get the connector off?
Thanks guys!
Old Nov 5, 2003 | 11:50 AM
96shogunmax's Avatar
Use a flathead and bump it off w/a hammer. It will probably crack the old one, but it will come off and you dont got to worry w/it b/c you already have a new one.
Old Nov 5, 2003 | 11:58 AM
Brian98SE's Avatar
Okay, what's the best way to get at it? So far I've managed to not take anything major off to get as far as I have. I guess I'm stuck removing the air intake and other things attached in the vicinity?
Thanks for the quick reply!
Old Nov 5, 2003 | 07:00 PM
Maximum96's Avatar
What does that switch do anywayz?
Old Nov 5, 2003 | 08:20 PM
Well to tell you the truth. I replaced mine while the tranny was out when I was doing the 5spd swap. I really couldnt tell you. I think its on the very bottom. So go under the car and get it that way. This is the spot I used to drain the tranny fluid, so yeah from the bottom.
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
