Need quick help for a problem installing a pop charger
Old Nov 6, 2003 | 06:54 PM
ManualMaxima's Avatar
5th Gen till she dies!
i was going to install my pop charger. i got the stock airbox removed and theer is a sensor i need to know what to do with and what it is.
OK the air enter the stock intake wear the hood almost opens. and goes past the battery. and right before it gets to the stock air filter there is a sensor. I have no clue what do. What did you all do with this, and what is it.
Old Nov 6, 2003 | 07:17 PM
plurco's Avatar
it is an air temp sensor. either locate it right beside your filter of do as I did and drill a small hole in your MAF and locate it there.
Old Nov 6, 2003 | 07:22 PM
1996blackmax's Avatar
I am not sure if you are talking about the ambient air temperature sensor. On my car I don't have a sensor before my stock air filter, but there is one after it, on the top part of the stock filter housing/intake. If this is what you are referring to, just zip tie it behind the pop charger. There is a metal bracket that attaches to the top part of the MAF, where the MAF gets bolted to the intake, on the top bolt closest to the firewall. I reused this small gold colored metal bracket on my JWT intake, wrapped the excess ambient air temp sensor wiring around it, and zip tied it to . Had no problems.
Old Nov 6, 2003 | 07:39 PM
i continued installing it and i just left it be to see if anything would happen. The service engine soon light came on. so postion it right next to the filter? it is like plug type sensor. i just hope t does not mess anything up.
JRod28
Dec 29, 2023 09:56 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
