codes 0304 knock senor and 0401 air temp senor
Old Nov 7, 2003 | 11:55 PM
maximaisokay's Avatar
Hi,
After cleaning inside of my throttle, the codes came on. I know where knock senor is located. And, I dont know where air temp senor is in my 98 SE. How can i solve the air temp senor?
Y.
Old Nov 8, 2003 | 12:01 AM
97blackSE's Avatar
Air temp sensor is something that sits inside the intake path and does what the name says...It probably fell out... Locate it, and place it through a slip Into your midpipe, or whatever you have...
THe knock sensor is probably just a ghost code from your intake temp sensor...
fix that, reset ecu, hope that ish doesnt come back!
Dont know how to reset ecu? Faqs!
good luck!
GB
Old Nov 8, 2003 | 06:31 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
try searching
Old Nov 8, 2003 | 10:01 AM
97 thanks for the tip. the plug was half plugged, so I pushed it back really hard. The light has finally come off.
ste, I did that and your tip sucks.
Y.
ballerchris510
Sep 23, 2015 08:46 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
lux97Max
Sep 4, 2015 05:42 PM
