Okay i have only one more intake questions. where did you relocate your boost sensor?
OK i go my air temp sensor handled. I got it to work inside the intake. Now, i got most of the stock air box removed exept, the part where the air enters and it goes to the filter box. On this at the very front attached is the boost sensor( or also called absolute pressure sensor). I need to know eher to relocated this so i can remove all the stock air box crap.
I put my intake in and never noticed the boost sensor hanging around until a week later.--I just got some of the metal mounting pieces form the stock intake and rigged up a mount for the sensor----if you look at your engine and towards the bottom right corner(not connected directly to the engine) is some metal pipe that has a screw hole in it( did it a long time ago so i cant remeber exactly where it is located and i just got home from bagging groceries and dont feel like looking)--i just put a bolt throguh my riggged up mount and bolted it to the pipe and then bolted the sensor to it--and its been just perfect ever since--if you need a picture ask and i'll see about getting one
Originally Posted by ManualMaxima
i went to home depot and got a long aluminum bar. bent it and drilled some holes. and not i have a boost sensor stand. it looks cool and works perfectly.
cool stuff
hey i used to live in lawrenceville-- abadern forest was my neghibor hood and i went to gwin oaks elementary
lux97Max
Sep 4, 2015 05:42 PM
