4th gen Illumina\Tien install completed
Welp, it's nice and late here in FL ... about 12:45 in the am and I just got home from a friend's house (thank you so much Aaron and Chris ... I still owe you another dinner or a coupla' six packs) where we installed the Tokico Illumina / Tien S Tech spring install. I was previously riding on blown Tokico Blues and Eibachs. The ride with the blown struts is nothing short of awful. Install was relatively uneventful aside from not torquing the piston nut enough on the driver's side, but that was solved with relative ease once all was said and done.
The Ride
The ride is damped, yet firm. The front spring rate is less than Eibach (201 vs. 320) but the adjustable struts (set on 2 out of 5) more than dampen the ride. Comfortable and handled pretty well in the twisties. I need an alignment big time so I will probably be even happier with it.
The Drop
With my previous combo my drop was relatively uneven. Many Maxima owners report an even drop with Eibach but I wasn't so lucky. The Tien's are a 2.2/1.8" drop F/R compared to 1.5/1.3 F/R (IIRC) on the Eibach's. My drop with the Tien's is almost dead even. The rear sits about 1/8" higher than the front right now and could settle down. Even if it doesn't it's close enough for me. My Eibach's were far too staggered - very noticable.
The Conclusion =
I'm very happy. Great drop, great ride and adjustability right on the strut piston.
And I know what you all are thinking ... and you're right. Pics to come tomorrow morning - afternoon once I can wash all the grease off it and get it lookin pretty. I'll also be comparing to my Eibach drop with some recent pics of the old suspension setup. Should prove interesting ... stay tuned.
The Ride
The Drop
The Conclusion =
Great info. I am riding on eibachs and blown tokico blues and can't wait to see the comparison pics. Just off hand how much additional drop did you get? I have a 3 finger gap with the eibachs and would like to go down another 1/2 inch.
In my next spring and strut upgrade I am going to be more worried about comfort. How much smoother, if at all are the tiens?
Eibach / Tokico Blue
Tien S Tech / Tokico Illumina combination
I also made an animated gif that switches these two images superimposed on each other. It's not great, but if you look at the shift in the front end it's very obvious.
See the drop for yourself ... it's a solid one inch lower up front IMHO if not more. It's a tight two finger gap I'd say. The tiens are much smoother and will really take the twisties pretty well. I will have more accurate data after my alignment - but for now I'd say it holds as well as the Eibach's did when they had real struts in them.
Originally Posted by voltman
Are you using camber bolts or plates or anything?
The drop looks similar to sprint springs. I was expecting the drop to be something similar to my sig.
Here is a pic of my car on sprints.
http://images.cardomain.com/member_i...030_7_full.jpg
are you bottoming out? with eibach & illuminas I bottom out A LOT(compare to AGX... but I slow down for everything wtih agx since they're so rough). I got modified rear strut mounts, kyb rear boots and front dust boots with 1/3 of the stock bumpstop.
Thanks for all the nice comments.
i saw 1fastmax's car last night at meeting and i can tell ya that those sprints do sit alot higher in the back than front. i hated sprints cuz of that but now im considering teins. bad *** even drop. BIG HAM, if u add the stillen kit, how much the gap between the kit and ground would be? any estimates?
I was also thinking about progress untill now but i see that teins are bad *$$. how much are they and where can i get them?
aslo, can u tell me the current gap in inches please? im really considering teins now!
yea, those are the teins, but i didnt think it was that obvious (well, he put all those pics for the reason of showing the new set up, so that element was obvious, but just by look it wasnt to me) also doggy, dont quote ALL the pics next time, just one might do
Originally Posted by Y2KSESteve
Looks awesome Joel! If I'm not mistaken yours is the first 4th gen with the Teins?
Thanks again for your help Steve, I'm very appreciative. I'm actually about to email you about the brake pads and how we can get the OEM ones ...
Originally Posted by Big_Ham
Your azz is sitting a little higher than the front in that pic. That's why I chose Tien and not Sprint for fear it would be too "raked" with Sprints. Also, as I said before, 5th gen's tended to have great, even drops with them.
Ok i see.
That's what I'm thinkin' But I'm really not sure.
Originally Posted by PeTeRtheEaTeR
hey big_ham...are ur springs settled in yet? how's the ride after settling in?
The one problem I do have is that I have some unidentified suspension noise, but I haven't taken the time to diagnose it yet, so it could just be a loose top hat or something similar that is easily remedied.
that's good news...i just purchased a set of illuminas and i'm currently riding on maxspeeds with stock struts but even with maxspeeds it doesn't look dropped compared to stock so i was considering the teins. So maybe somewhere in the middle of January i'll probably have the same setup as you do. Thanx for the info.
Looks good Big_Ham! Very similar to my drop of Sprint springs with 1 coil cut in the rear. Handling will be great due to the lower COG. Sprints also ride very rough, but I love that feeling. Unfortunatley with my new b-pipe I am scraping on my driveway, so I decided to go with Tein H-Techs. They will be here soon and I hope I am as happy with those as you are happy with yours!
-Cyrus
-Cyrus
