Check engine light diagnosis problem
Old Nov 9, 2003 | 02:35 PM
MaxDiva's Avatar
Yes I read the sticky. And I searched.
I walked out to my car armed with a philips and a regular screwdriver. I removed the black cover near the gas pedal. Here's my problem. There isn't a screw there. And the sticker that covers that hole says it's an idle speed adjustment. How am I supposed to find out why the check engine light is on? Besides taking it to a dealership that is?
Old Nov 9, 2003 | 05:36 PM
PoePoe2797's Avatar
99's are different.....only 95-98 have that screw. Goto Autozone.....theyll check codes for free
Old Nov 9, 2003 | 06:37 PM
bananamax's Avatar
Ummmm NO. 99's DO have the screw. My car even has the newer ECU, and it has the screw.... Works wonders. You just need to cut the sticker away first. Also, I've found that an electronics screwdriver works best. THe screw is small, plastic, and easy to strip...Careful! Good luck.
Old Nov 10, 2003 | 05:43 AM
Kevlo911's Avatar
Kevlo for President
take a flashlight and look in the hole towards the bottom, you will see a small plastic screw, be very careful when turning it because it will break easily
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
