I think I have...
Old Nov 12, 2003 | 12:48 PM
Linkage23's Avatar
I think I have...
So I really think I have a VLSD. I bought the car in Alaska but I think it was originally a Canadian car. How can I tell without having to research a lot if I truely do have a VLSD?! When I butter up the pavement I leave two launch marks/burnstrips. Is this a precursor to VLSD or does this occur to the open diff Maximas also?
-Lieb-
Old Nov 12, 2003 | 12:49 PM
Jeff92se's Avatar
I'm needing a caw
got echo? asfd
Old Nov 12, 2003 | 12:50 PM
NmexMAX's Avatar
dot dot dot ...
I dunno if this works with our maxis but on older muscle cars jack it up and put it in Nuetral and spin one tire and look at what the other does. I leave 2 launch marks also, so that not a direct indication.
ivelweyz
all maximas, even without VLSD usually leave 2 strips. I just left 2 behind today in my auto, new KS is really working. But to be sure I think you have to decode your VIN or one of the tags on the firewall. Search I know it's somewhere, maybe the FAQ...
Old Nov 12, 2003 | 12:54 PM
NmexMAX's Avatar
dot dot dot ...
Yeah, check the VIN
Old Nov 12, 2003 | 12:57 PM
Linkage23's Avatar
Thanks, I was actully hoping the two burn marks were VLSD. I guess I have another chunk of change to spend. Thanks for the help.
-Lieb-
Old Nov 12, 2003 | 01:10 PM
ivelweyz
vlsd only helps in cornering and handling aspects. Drag racing and straightaway driving don't benefit from it...
Old Nov 12, 2003 | 02:12 PM
Kevlo911's Avatar
Kevlo for President
i think CDN 5speeds had VLSD
Old Nov 12, 2003 | 03:49 PM
KMax2988's Avatar
Look on your firewall for a silver metal plate with numbers punched on it (located on passenger side). This plate contains your tranny code, interior code, etc. Look at the one that says trans. code and if it reads RS5F50V then you have a VLSD, otherwise it will read RS5F50A. Those codes are for manual transmissions, not sure about the auto code (RE4 sumthin). At the end, tho, you will notice either an A (open diff) or a V (VLSD) respectively.
NismoMaxman2
Jan 28, 2008 12:03 AM
f550maranello2
Sep 7, 2007 05:31 PM
Fastmax05
46
May 29, 2007 12:45 PM
