Cold Hard Start
Old Nov 13, 2003 | 06:33 AM
union122's Avatar
Cold Hard Start
Hello all, my first post...
my 98 se auto max. is cutting off when first start up in the morning. this is my first cold season with this car. i did a search and for far, i did:
1. checked the battery and alt.
2. replaced fuel filter
3. replaced plugs
so the first start ( usually in the morning ) once the car is cold, its cranks and starts, then in 1-2 seconds justs dies, rev. just goes down and the car cuts off.
any ideas ?
thanks
Old Nov 13, 2003 | 07:00 AM
NmexMAX's Avatar
dot dot dot ...
Throttle body cleaning might help. . .Just a sugg.
Old Nov 13, 2003 | 12:05 PM
Drewmeister's Avatar
I have the same problem and am browsing the forum here for ideas. Sorry, I can't offer any suggestions, at least, not at this time.
Old Nov 13, 2003 | 12:49 PM
LastBoyScout's Avatar
okay guys. when was the last time you did an oil change????
you probably need to. Go and get some Castrol GTX 5w30. Since it is 5 weight, it is thinner and can get to the smaller parts of you car easier. This is helpful in the wintertime since cars will stall when they are not properly lubricated.
try that and then see what happens.
Old Nov 13, 2003 | 05:31 PM
chiwchan's Avatar
Same problem here. Happened today at like 5:40 PM in Jersey when I left work. After starting, pressed gas pedal to rev engine slightly to keep from stalling then everything was okay. Only happens when its gets really cold....
Old Nov 13, 2003 | 05:48 PM
shuefu's Avatar
I also have a 98 SE auto and have this problem sometimes in the winter. I sometime park in my driveway which is a little slanted, I wonder if that contributes to the problem at all. Maybe it's something the 98 SEs has??
Old Nov 13, 2003 | 05:54 PM
happyricefob's Avatar
V^___^V
check also the following:
1. clean air filter
2. clean throttle body
3. clean IAC valve
4. replace oil filter + oil every 3,000k, peferably sythetic oil with OEM nissan oil filter. if you live in cold area use 0W-30, if you live in hot area use 10W-30. in between use 5W-30.
5. check spark plugs
6. reset your ECU after all that.
Old Nov 13, 2003 | 07:48 PM
cerumo's Avatar
3. replaced plugs
any ideas ?
thanks
I had this problem before. After a while check engine light came on ocassionally. Scanned it, it was the coolant sensor. The car doesn't have this problem anymore since I've replaced the coolant sensor.
Old Nov 14, 2003 | 06:31 AM
TXtoTNmax's Avatar
cold start
I also have a 98SE auto and i have problems starting in the morning. My belt seems to make a chirp when turning over and then the revs fluctuate before idleing consistently. it is weird?
RinconI30
Nov 10, 2015 10:55 PM
fastcarny
Oct 6, 2015 10:42 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
