Do all alternators fit all 4th gens?
Old Nov 15, 2003 | 11:38 PM
Bmr4life's Avatar
I've got a 95 Maxima SE with 133k miles and my alt is screaming. I found how to replace it on motorvate but don't know what all ones fit which years. Also, is there any other alternator that will fit in my Max without modification that would produce more amps? maybe like pathfinder one or something?
Old Nov 16, 2003 | 02:01 AM
Nismo's Avatar
all 4th gens sould be interchangable. The ones that come with foglights from the factory have a slightly higher amperage than the base models.
Old Nov 16, 2003 | 08:51 AM
Bmr4life's Avatar
thx, does anyone know of a larger amp alt that fits without modifications?
Old Nov 16, 2003 | 02:30 PM
Maxima99SE's Avatar
will fly for food
I've heard that I30 alternators fit w/o modification.. not 100% on that one though, so if anyone is 100% sure on that one...
Old Nov 16, 2003 | 05:56 PM
Nismo's Avatar
Of course they fit because its the same exact engine
Old Nov 17, 2003 | 07:19 AM
Larcenist's Avatar
Well, not really. I have a '97 maxima and replaced my alternator with a '99 alternator and I had issues. The alternator size was the same, but the problem was with rotating circle that holds the belt. On the '99 alternator it had more or less "teeth" (i forget if it had more or less) then my '97 alternator. So after 2 altertantor belts were ripped to shreds within days of the install, I noticed this problem. So I had to goto a mechanic to have them remove the circle rotating thing on my '99 alt and replace it w/ the '97.
Old Nov 17, 2003 | 07:59 AM
ejj's Avatar
ejj
I've currently got an alternator from a 95 on my 99 with no problems at all.
Old Nov 17, 2003 | 08:38 AM
maxS
all altenators 95-2001 maxima/i30 are interchangeble, exept that 95-99 are 125 amp and 2000-2001 are 110 amp. No difference in connectors or pinout of those connectors.
Old Nov 17, 2003 | 09:10 AM
Ninos_Maxima's Avatar
be the change u want2C
Isint it better if you have more amps, I heard your alternator recharges your battery faster or something.
Old Nov 17, 2003 | 12:29 PM
Bmr4life's Avatar
yeah, the more amps the better. You can never have to large of an alternator (current wise)
Old Dec 12, 2003 | 01:34 AM
thomasd cook's Avatar
So will the 4th gen. 125 amp alt. fit a 5th gen. Max?
Old Dec 12, 2003 | 08:34 AM
maxS
I do not see why not.
Old Dec 12, 2003 | 08:39 AM
deezo's Avatar
There are 2 different alternators for 4th Gens. The higher amp alternators have a different pinout in the connector.
Old Dec 12, 2003 | 08:45 AM
Nismo's Avatar
Are you shure? I had a SE alt in my GXE once when the 97 recall happened
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Former3G
Oct 26, 2015 11:34 PM
Finkle
Sep 27, 2015 09:53 PM
