Engine dies under load
Old Nov 18, 2003 | 08:38 AM
dgeesaman's Avatar
Maintenance Monster
97 SE 5sp, 110k.
I did an oil change, topped off the ATF and coolant, changed air filter and cleaned my battery terminals on Sunday. I didn't run the car afterward but the next morning it stalled when I tried to engage the clutch in reverse. CEL came on and stayed on. I didnt' have time so I drove my RX-7 to work, but this morning the same thing happened with the Max. I noticed it was immediately idling at 900rpm even though it was cold. I managed a trip around the block, but it shuddered under throttle and died if I blipped it with the clutch in. It was not driveable, so darn I had to drive the fast car today.
TB is clean and the fuel filter has 30k but shouldn't be bad.
I've read about the coolant temp sensor, IACV, and the wiring problem that FLO_BOY posted about in April. I did spill a little coolant when filling, so maybe that caused it.
Suggestions on what to try first and how to do it. The CEL is now clear - is it worth trying to read the codes the manual way? (and slightly off-topic - is a code reader a worthwhile investment for this car?)
Dave
Old Nov 18, 2003 | 11:03 AM
Street Reeper's Avatar
Handsome
It sounds like a MAFS problem. Check to make sure it is plugged in, also did you put a new filter on that came oiled? Sometimes oil from the filter can get on the little metal parts of the MAFS and cause it to seem as if it has failed. A simple way to check if it is the MAFS is unplug it and try to drive it. If it has the same problems than that is it.
Originally Posted by dgeesaman
97 SE 5sp, 110k.
Dave
Old Nov 18, 2003 | 11:40 AM
dgeesaman's Avatar
Maintenance Monster
sonofa*****. That's it.
I dont' remember plugging it back in. I unplugged it to squeeze in that air filter and forgot about it when I tried to retrace it all in my mind.
Cheap fix, but damaging to my ego.
Dave
Old Nov 18, 2003 | 11:44 AM
1FSTMAX's Avatar
97 SE 5sp, 110k.
Dave
You put ATF in your trans? I thought you have a 5spd?
Old Nov 18, 2003 | 12:15 PM
dgeesaman's Avatar
Maintenance Monster
In the power steering reservoir.
Old Nov 18, 2003 | 12:33 PM
Handsome
Dave
Glad I could help, let me know if you ever need anything else.
shilov
Feb 19, 2024 09:40 PM
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
