Is the loose cat heat shield rattle intermittent or constant?
Old Nov 20, 2003 | 02:36 PM
voltman's Avatar
Is the loose cat heat shield rattle intermittent or constant? I sometimes get what sounds like either a rattle or some kind of weak metal contact around 3000 until 4500ish rpm while driving. It's intermittent and when it does happen, it's only under load. Heat shield? Tensioner? Loose random part?
Old Nov 20, 2003 | 04:07 PM
ivelweyz
Unless you get under the car and see what is loose how are we supposed to know what's wrong? There are MANY things that can be loose so I suggest you get under your car and find what's wrong...
Old Nov 20, 2003 | 08:58 PM
Mad Dhan's Avatar
i had a rattleing problem. It was that metal part that goes between the cat and y-pipe. I think people refer to it as a hanger. I just bent it away from the body and problem was solved.
I might have a pic, lemme see
Old Nov 20, 2003 | 09:00 PM
Mad Dhan's Avatar
yeah, bend these two bad boys out the way
http://home.socal.rr.com/dhan/Bend%20this.JPG
Old Nov 21, 2003 | 09:55 AM
voltman's Avatar
Thanks. I'll look into this weekend.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
