Anyone has LED bulbs in their tails?
Old Nov 20, 2003 | 03:13 PM
Ladzio's Avatar
I was looking long ago at these LED bulbs ($6/per 1) and when today the bulb burned out in my first gen Altezzas I decided to give a try and get some. But before that would like to hear what others have to say about them.
Are they any brighter indeed than stock 1157s. How do they look? Do they last? Would getting Polargs ($8/per 1) be a better decision?
Thanks!
Old Nov 20, 2003 | 03:25 PM
Ravq's Avatar
I don't recommend you use them in your tails. The light output from the LED bulb doesn't shine like a normal bulb. The light is focused mainly in one direction and will not scatter normally.
Old Nov 20, 2003 | 03:27 PM
bobjohnson's Avatar
Blazin......
yeah check general maxima discussion too.
http://forums.maxima.org/showthread.php?t=258730
3 threads down
Old Nov 20, 2003 | 03:33 PM
PoePoe2797's Avatar
Thats a little different....he meant as a replacement to stock bulbs, not completely redoing his lights
Old Nov 20, 2003 | 03:36 PM
araffio's Avatar
You're correct. Having a single 1157 red LED bulb will not scatter light to the sides, which will give you a dim dot in the tails during the day and a bright dot at night. That is the only downfall to LEDs, they only throw light straight.
You could always make LED tails like mine, only took me ~70 hours to make them, no biggie
-Tony
Old Nov 20, 2003 | 03:51 PM
Ladzio's Avatar
-Tony
Yea, your tails rock, I think there is no member on the .Org who does not know your car.
Well, Altezzas do have a sort of "diamond cut" glass to scatter the light. However I believe you are right, one LED bulb wouldn't do a good job. What about Polargs, how come they are brighter with the same specs as any stock 1157s, or they are not the same?
Old Nov 20, 2003 | 04:06 PM
SXN's Avatar
SXN
a single big LED wont spread light to the whole lense, and will look horrible. araffio did something quite different
Old Nov 20, 2003 | 04:23 PM
Frank Fontaine's Avatar
Yeah, I was behind a FX45 tonight, and when he put on his signal, the glare was very annoying. What works on the DeVille and S500 clearly does not on the Infiniti. Poor design. Nissan needs to somehow meld design with fashion imho.
Old Nov 20, 2003 | 04:49 PM
SXN's Avatar
SXN
some people have used thicker lenses...doesnt let as much glare through, and it spreads the light better across the whole lense...but it still needs perfection
Old Nov 20, 2003 | 07:55 PM
blkhawk500's Avatar
What these type of LEDs, but in red. Anyone every tried them?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444199528
Old Nov 20, 2003 | 08:02 PM
SXN's Avatar
SXN
those would also focus the light only in one place...not spread it across the lens.
Old Nov 20, 2003 | 08:08 PM
GodsmackMAX's Avatar
I have LED bulbs in my tails (GenII) and they look pretty sweet!!! Just got the ones from AutoZone. I think the brand name is Jamstrait? If you are going to use them in your turn signals, u need to get a load resistor. I ordered mine from superbrightleds.com. I have red turn signal LEDs and white LED bulbs for reverse. I will see if I can get some pics tomorrow.
Old Nov 20, 2003 | 08:16 PM
SXN's Avatar
SXN
yea, gen2s with the little circle lenses focus the light in one single place... with redclears, you have a big flat open lens you need to light
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
