MY CAR SHOULD BE IN THE NEXT "GOT CHOCLATE MILK" COMMERCIAL! brake problems !
Old Nov 22, 2003 | 09:24 AM
DoGGy
when i brake on freeway at speeds of 60+ mph, my car shakes EXTREMELY bad and i have noticed that this also happens in the streets but since im at slower speeds, its not really noticeable. but i do notice that my car doesnt stop good. it takes 3 or 4 times longer than my 96 altima to stop. i use ceramic brakes. last time i had my rotors resurfaced was on january 03. anyone have any ideas?
thx mates !
Old Nov 22, 2003 | 09:30 AM
ILoveMyMax's Avatar
alignment?
Old Nov 22, 2003 | 09:31 AM
DoGGy
Originally Posted by ILoveMyMax
alignment?
umm. i forgot to mention that the car itself shakes at speeds of 70+ maybe thats because of the big wheel gap? engine has 25k.....
Old Nov 22, 2003 | 09:33 AM
mendon11's Avatar
wheel gap? i havent had my car lowered or anything (stock everything suspention wise) and i feel fine, even at speed at 90+. maybe it is alignment. i seem to recall you mentioningthis problem a long time ago....?
Old Nov 22, 2003 | 09:44 AM
nadir_s's Avatar
vicodin ... gift of life
brakes sounds like the rotors are warped?? If the car is shaking, get an alignment / tire balancing.
Old Nov 22, 2003 | 01:31 PM
Kashoggio's Avatar
thx mates !
if you car shakes when you are braking, its a brake problem, most likely is a warped rotor. If your car shakes just crusin, its wheel , tire or suspension problem. THe first thing to do is to balance your tires
MIke
Old Nov 22, 2003 | 01:36 PM
GoldenGlory
yup those are your rotors, they are gone.
change them asap along with OEM nissan pads.
Old Nov 22, 2003 | 03:56 PM
skeelo34's Avatar
If your steering wheel shakes, your wheel lug nuts might be loose. Also, most likely need alignment and new rotors. But check if your nuts are loose!
Old Nov 22, 2003 | 05:27 PM
nismology's Avatar
What would alignment have to do with vibration?? Bad alignment causes the car to pull to one side and/or requires you to hold the steering wheel turned for the car to go straight. Sounds like warped rotors/unbalanced tires. One thing to help to minimize rotor warp when slowing down from high speeds quickly is pressing down on the pedal decisively to help the rotor keep its shape as opposed to moderate pressure.
Old Nov 22, 2003 | 06:33 PM
NissanSE98's Avatar
---occasionally my brakes give off a "scrubbing" noise"---i think i read something a long time ago about that being a problem in 4th gens....
Old Nov 22, 2003 | 09:15 PM
ManualMaxima's Avatar
5th Gen till she dies!
cha ching!
Old Nov 22, 2003 | 09:41 PM
KWheelzSB's Avatar
warped rotors. Time for replacement.
Old Nov 22, 2003 | 11:48 PM
DoGGy
car shakes when i brake at 60mph+ and also shakes when i cruise at 80mph or so !
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
RealityCheck
Aug 5, 2015 06:18 AM
