What guage wire to use for blinker rewire?
Old Nov 22, 2003 | 07:28 PM
proguitar04's Avatar
I'm doing the blinker rewire where the corner light alternates with the blinker. I have the wire taps, but I'm nto sure what guage wire to use. The search page is down, otherwise I'd put up a link to the site where the directions are. ANYWAYS, I need to know what guage wire to use. I believe that the tap goes on the positive of the side marker. If anyone knows the answer ot this, please reply!!! thank you.
Old Nov 22, 2003 | 08:53 PM
Sin's Avatar
Sin
You don't need anything major. Even 16 gauge will probably be enough. Also, I highly suggest not using wire taps. One, they often don't pierce the insulation well, and definetly do not protect the connection adequately from the environment. I suggest slicing through the insulation with a razor or wire strippers, pulling the insulation apart a bit, wrapping the new wire onto the exposed section, soldering, then heat shrinking. This is exactly what I did, and the proper way to make an electrical connection like this, that will face moisture and the environment due to its location.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
