Mysterious oil leak, please help
Old Sep 18, 2000 | 10:40 PM
I recently noticed that I have a small oil leak under the front of the engine. It appears that oil is dripping from the wires coming off the oil pressure sending unit. I had a shop look at it and they said I had a leaky oil sending unit. I had it replaced just 8 months ago, but I went ahead and had it replaced again. Unfortunatley, the leak is still there. Any ideas would be appreciated.
Old Sep 19, 2000 | 05:59 AM
Max96's Avatar
Yeah, my '96 had the same problem. I changed it and it has been good since. Is it possible that whoever changed it didnt torque it in there enough? Dude, just grab another one, there only around $10. Next time you are under there changing the oil, just swap it out. It is possible that the new unit you got was defective to begin with. Working in the auto parts business for 9 years, I have seen LOTS of things like that happen. Good luck.
[Edited by Max96 on 09-19-2000 at 12:33 PM]
Old Sep 19, 2000 | 06:26 AM
Well, I replaced it myself and made sure it was well-torqued. I don't know how much torque should be applied (even the FSM doesn't specify it), so I just tightened it up as much as I could without stripping the thread. Thanks for the reply.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
