clutch thickness...
clutch thickness...
how thick should a nissan oem (not key value) friction disc ---ie. clutch be when brand new for our cars......does anyone have a good pic of what the disc looks like when brand new....just curious....
how do you know how worn the clutch is by looking at it? are there any common signs by looking at it....as you can tell, i have it outside the car right now...
http://www.cybrrpartspro.com/Chilton...961CH07_8.HTML
You have to measure it. Off hand, if it's been 30-40k, might as well replace it unless you plan for a fidanza in the future.
can't measure it with a ruler...have to find something else to measure it with...i think im just gonna take this to a mechanic and see what he thinks...do you know if the friction disc on courtesy nissan is the key value or the real oem one?
Why not be prudent and visit an auto store and browse though their service manuals? Or buy a Nissan FSM? For work like this I can't believe you don't have one already. How do you know what to torque everything down to????
Originally Posted by michaelnyden
well nobody answers my first questions....so i have to be presistant
Get the OEM NIssan clutch CHEEEEEAP!
Daikin Clutch kit - 4th Gen. Maxima's OEM clutch - (NOT Key Value)
Get in touch with John (aka: .org member "Clutch King") at Direct Transmission Parts in NY.
800-989-8726
His part #: 06044
The kit includes the friction disc, pressure plate, clutch release bearing & alignment tool - everything you need.
I won't quote his price online here, but it's much less than Courtesy N., or anywhere else I found - trust me on that. I received the clutch kit just the other day as promised & highly recommend this seller/.org member.
-K-
PS: My new replacement clutch measures 9mm thick from the face side of the friction surface to the backside of the friction disc. The thickness from the friction surface to the highest rivet measures 3mm, so apparently that 3mm is the "new" specification, not the minimum safe thickness. Anyway, hope this helps.
. . .and yes, buy a FSM or Hayne's manual - well worth the investment.
800-989-8726
His part #: 06044
-K-
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
