Manual Tranny Question
Old Nov 24, 2003 | 05:08 PM
sean05's Avatar
I was wondering if anyone has ever has problems with their manual tranny. My car has 80k miles. Should it have problems? anything i need to look out for?
Old Nov 24, 2003 | 11:17 PM
KWheelzSB's Avatar
Yes. 108k mi. Failing differential bearings.
Old Nov 24, 2003 | 11:54 PM
meccanoble's Avatar
Sports Button FTW
4th gens, mainly 95-97 (mainly 97) have been known to have a lot of tranny issues. If you do a search you will see dozens upon dozens of people complaining about how their tranny died on them, a lot even at an early age. At 80k, your engine is in tip top shape (if standard maintenance have been done) but tranny, it all depends on your driving and your luck. Nissan Maxima's are great cars but its only flaw is tranny issue. Many have blamed on aftermarket clutches.
Old Nov 25, 2003 | 03:24 AM
pblaze's Avatar
My car is rolling up on 100K miles this year, and I think it's starting to show signs of a diff. bearing failure too. You know that whine you hear in first or reverse? I'm starting to hear that in all gears. Under engine braking it's most noticable to me. When I just tip the throttle in to remove the load, the sound disappears.
My car has acted like the differential is improperly shimmed since the day I got it. In first or second during an on-off-on throttle transition, it feels real jerky. I have a feeling that the ECU causes part of this problem, but driveline lash is a factor too (IHMO).
There's a great website on the problem and the repair here: www.motorvate.ca/mvp.php/804
Old Nov 25, 2003 | 01:32 PM
sean05's Avatar
Thanks guys. I just hit the 80k marker so i think im good as far as the tranny goes!!
Old Nov 26, 2003 | 02:48 PM
whitenas's Avatar
208k original motor tranny and clutch
Old Nov 26, 2003 | 08:40 PM
Ladzio's Avatar
100K hit yesterday. Tranny is jerking bad. Ordered some Redline MT-90 to make shifts smoother, hopefully it can last till summer when I could squeeze out some cash to have it fixed....
Old Nov 26, 2003 | 09:02 PM
KWheelzSB's Avatar
It may be something as simple as a bad tranny or engine mount. I wouldn't let your drivetrain slop around like that for several months. . .ignoring the problem may make it worse and more expensive to fix. Consider at least having it checked out for now.
Old Nov 26, 2003 | 11:46 PM
Oblongshapes's Avatar
I had to replace my clutch(103), and my o-ring went, it was leaking really bad(108).
Old Nov 27, 2003 | 07:39 AM
KWheelzSB's Avatar
By "o-ring," do you mean axle seal?
pktaske
May 6, 2016 07:49 AM
pjgreek
Sep 9, 2015 09:30 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
