5sp swap; driveaxle stuck
Old Nov 24, 2003 | 05:46 PM
1991tsi's Avatar
well, since the search function is disabled, i'll post my question:
i'm in the process of a 5sp swap, having trouble removing passenger driveaxle from 5sp donor car. I removed the 3 12mm bolts from the support bracket, but nothing seems to be loose. anyone else have this problem, any suggestions?
thanks!
Old Nov 24, 2003 | 06:53 PM
nupe500's Avatar
Jedi Knight
you've got to break loose the rust holding that piece in there...just tap it slightly with a hammer..and you should be all good
Old Nov 24, 2003 | 07:29 PM
1991tsi's Avatar
i did some pounding and yanking, trying to be gentle. will it separate at that bracket or pull out of the tranny itself??
Old Nov 24, 2003 | 07:31 PM
nupe500's Avatar
Jedi Knight
either way it doesn't matter...you'll have to separat it form the axle if you're replacing it...or hit it with some WD-40 and go to town...it can't hurt...just don't nail the axle itself too much and you should be A-OK
Old Nov 25, 2003 | 09:30 AM
dss42's Avatar
Yep had same problem there is a small clamp holding it inside just hit it a few times it will pop right out.
Old Nov 25, 2003 | 09:33 AM
ejj's Avatar
ejj
Un-bolt the bracket from the block and leave it on the axle. Then bolt that bracket onto your block.
When swapping engines I couldn't get the axle to seperate from the bracket...so that's what I did. However, I did it after too much pulling, and seperated the inner CV on the axle, and had to rebuild it.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
