Starting very difficult sometimes/running rough sometimes
Old Nov 26, 2003 | 03:51 PM
maxlife's Avatar
Starting trouble.
Symptoms: My 95 Maxima(140,000 miles) became difficult to start about six months ago. On an average, about twice a week, it will turnover for about 20 seconds or more before it starts. The rest of the time it starts right up. Maybe 1 time a week it will stall at a light. It seems to be getting slowly worse. It may be missing at a slow idle. Other than that it seems to run good, although I notice the shifting(automatic) more than I used to. I checked the error codes a few weeks ago by turning the screw on the computer clockwise and then counter clockwise and watching the check engine light blink and recieved 0505. Last night the check engine light came on and I checked the codes agian and recieved 0304 and 0707.
Things I have done: I changed the plugs(NGK Platinum). I changed the fuel filter(bloody knuckle buster). Air filter as well. I haven't noticed any change in behavior.
I see that the codes I received indicate an O2 sensor and a knock sensor. I find it hard to believe that both just went bad at the same time and also don't understand why I wouldn't have had one of these codes when the starting problem began if the two problems are related.
People have told me to change everything from fuel injectors, coils, fuel pump, all O2 sensors and a valve job(@#$%@).
Thanks in advance.
Old Nov 26, 2003 | 04:14 PM
JeremyMarkham's Avatar
Why dont you just take it in to the dealer.
Old Nov 26, 2003 | 07:46 PM
twiggy144's Avatar
ks code is most of the time triggered by another code in a domino effect. Fix all the other codes first, then drive for a while. Chances are the Ks code will not reappear.
Old Nov 26, 2003 | 08:27 PM
happyricefob's Avatar
V^___^V
cuz dealer is , that's what the org. is for.
anyway besides checking the knock sensor, have you check your engine coolant temperature sensor yet? that is also one of the major problem that hesisate starting. knock sensor is the second item you should definetly check it out.
you can look up on the FAQs in the 4th gen forum. basically you just need to get a ohmmeter, locate the engine coolant temperature sensor, test the voltage, and see if it is up to factory spec. if not, you should definetly replace it.
Old Nov 26, 2003 | 08:36 PM
SamMan23's Avatar
probably a good idea to clean or replace the rear O2 sensor. see if that takes care of it.
QueensMAX
Sep 15, 2015 04:14 AM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
trungg86
Sep 4, 2015 04:58 AM
