Ripped CV
Ripped CV
I'm having my clutch replaced at the moment. While under the car, they told me that my outer CV was ripped and that I had major grease loss. I don't really have the money to get this fixed, so should I worry about this part? What could happen if it stops operating properly?
Originally Posted by seximagtr
if you just want to replace the boot and repack the grease etc.... i can help you out with a boot and the grease... pm me if u want it.
Originally Posted by maxcross
What if the joint is worn and caked with road salt and sand? Is it worth the time to repack, or just replace the axle?
If the CV is not snapping and cracking I would just buy a boot ($10-$15) and replace it yourself. Clean the joint out really well with paint thinner or similar, dry and repack with grease that is supplied with the boot. I did one years ago and the CV is still fine. As well I just did another one and it's working perfectly. It's Really Easy!!
You will need to add gear oil when you gonna replace the axle because some gonna spill out when you take axle out of transmission, about 2-3 quarts.
Braker bar should brake that axle nut, however if it is pretty rusted, you can spend half a day trying to brake it, so in this case an air tool is necessary.
mikeg75
Nov 30, 2015 05:12 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
95naSTA
Sep 21, 2015 06:50 PM
