screeching when car starts in cold
Old Nov 28, 2003 | 10:17 AM
neptunemax's Avatar
Hey my car screeches while turning the car on in the cold what is that,? is it a belt or somehting? Do i have a problem ?
Old Nov 28, 2003 | 10:32 AM
MaxWilk's Avatar
You are correct that it is probably your belts. They are either worn or need to be tightened. If you have a Haynes Manual you can do this your self. Otherwise to adjust them is abour $35-$50 and to replace about $120.
Old Nov 28, 2003 | 10:44 AM
USRacer900's Avatar
If you have a 4th gen max., belts are $8.09 a piece at Autozone. One's for power steering, other for alt. etc. I'm replacing mine as we speak. Looks like it may take an hour or so, shouldn't be too difficult.
Old Nov 28, 2003 | 09:47 PM
1996blackmax's Avatar
Could also be your starter. I have this problem. I might tackle this issue as discussed at motorvate's site.
http://www.motorvate.ca/mvp.php/516
Old Nov 29, 2003 | 06:58 AM
Maximeyez's Avatar
Squeeeeeeeeeeling
Yeah, I know about this one. My 98 has been squeeling like a stuck pig whenever the engine cools down. The problem was a stretched power steering belt and a wiped out bearing in my tensioner pully.
I had the stealership do the work while they were doing my FREE alternator install(recall)
They charged me $50 to do the extra work since they had that part of the car already apart.
Old Nov 29, 2003 | 07:36 AM
Ladzio's Avatar
I hear more and more stuff about alternator recalls, to what years did that apply? What's the problem with alternators?
Old Nov 29, 2003 | 08:46 AM
Jepht20's Avatar
Custom User Title...
mine does this too...try checking that first...seems to be a very common problem.
Old Nov 29, 2003 | 10:16 AM
Ladzio's Avatar
yep, me too
Old Nov 29, 2003 | 05:42 PM
Bonka's Avatar
Schnell kaputt
Kind of a self-explanitory question, but this sccreech noise would only occur during startup and not afterwards during idle right?
Old Nov 29, 2003 | 05:51 PM
sk24iam's Avatar
I've had it during startup and last a little bit into idle. Also, I had mien changed about a month or so ago, and I recently started hearing it again.
Old Nov 30, 2003 | 12:31 AM
PeTeRtheEaTeR's Avatar
i have it too. It can be embarrasing sometimes.
Old Nov 30, 2003 | 06:08 AM
twiggy144's Avatar
some alternators cought fire. Nissan posted a recall on www.nissanusa.com. HAve your VIN handy to check your car.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
