2000 manual transmission in a 95 maxima
Old Nov 29, 2003 | 08:45 AM
Vinipux's Avatar
I just finished the install of 2000 manual transmission in a 95 nissan maxima, since the transmission is the same it will just fit and work. the only thing that you needed to transplant is the speedo sensor, I had to be careful because the top of the sensor was plastic and I didn't want to crack it, so I used 2 screw drivers and carefully got it out and installed it in the 2000 tranny. the speedometer seems to tell me the right miles an hour, although I still wanna check w/ another car on the highway. you do not need to get 5th generation axles, the original axles work just fine.
1 day impressions, I absolutly love it, the transmission feels much tighter, not in terms of shifting but in terms of driving sensation, and I don't know how but it changed the sound that the car is making, reminding me of my friend's 98 maxima, maybe the ratios are little different
and I almost forgot, for the most part you can get a cheaper 5th gen transmission then a 4th gen transmission, so for those of you who have bearing problems this is probably the best way to go. go to www.car-part.com and you can search local and national inventory. I got the non-locking one.
good luck and feel free to contact me for any information
p.s. (put good amsoil 75/90 fluid in the transmission, it will love it, mine does, contact me if you need any)
Old Nov 29, 2003 | 09:47 AM
calacro's Avatar
cool, but what is the diffrents between non-locking differential and locking differential? I would search the board, but I can't..
Old Nov 29, 2003 | 10:46 AM
Jatan's Avatar
http://auto.howstuffworks.com/differential.htm
It helps with wheel spin. It's like traction control or something...
Old Nov 29, 2003 | 12:06 PM
1FSTMAX's Avatar
Good to hear that it works. I want to see a 2k1 AE LSD tranny go into a 4th gen.
Old Nov 29, 2003 | 01:50 PM
Vinipux's Avatar
it should, I would assume it's the same tranny, but you might need different axles, at least you need it when you install the i30 lsd transmission. I really wouldn't waste my money on that, no reason to have it for everyday driving, but that's just a side note
Old Nov 30, 2003 | 08:37 PM
calacro's Avatar
thanks for the info
Old Dec 1, 2003 | 01:09 AM
kingrukus's Avatar
no more maxima...
Damn I would love to do this just to get my 5th gear to be more tall. The 5th gen 5th gear is more tall, correct?
Old Dec 1, 2003 | 05:38 AM
Ladzio's Avatar
Is 2K transmission 5sp or 6sp?
Hmm, I will have to fix up my tranny soon and I am tempted to go with 2K now
Old Dec 1, 2003 | 07:10 AM
BEJAY1's Avatar
Conecarver
Been there done that.
http://forums.maxima.org/showthread.php?t=232060
As for gear ratio's the 2000 and 2001 are about the same. .80 vs .795 in the 4th gen. Somebody on the .org did change to an Altima (.74) or similar 5th gear successfully. I didn't hear about it til I was already done.
Old Dec 1, 2003 | 10:04 AM
Vinipux's Avatar
does the 5th gen tranny have slightly different gearing everywehre or just 5th gear, because it almost feels that it's little bit different everywhere but it could be in my head
MAXSE5SPD
Aug 23, 2015 12:06 PM
ef9
Aug 13, 2015 01:19 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
