Help installing O2 sensor
Old Nov 30, 2003 | 02:42 PM
lilgrebbie's Avatar
My front right heated o2 sensor went out. I ordered the part from oxegensensors.com. I got it the other day and scince its nice out i decided to put it in. The one i got has 2 black wires and one blue, while my cay has 2 white and one black. I read the insteructions but couldn't make sense of it all.
I assume that I put the 2 black on the 2 white and the blue to the black right?
also I posted pics of my tranny leaking a little bit ago. I still havent found out whats wrong with it so I want to add tranny fluid because it is getting low, is it ok to mix brands scince I don't know what kind is in there?
P.S. the tranny fluid reservoir is the white semi-transparent cylindrical shaped one on the passenger side correct?
lilgrebbie
by the way its a: 1996 SE 5-speed
Old Nov 30, 2003 | 05:07 PM
MAXTOUT's Avatar
I am going to be doing this pretty soon. I pulled the code for the front right heated O2 sensor, but I am not sure what that is. My assumption is that it is the O2 sensor on the front bank of the y-pipe, right?
How much did you pay for the O2 sensor?
Old Nov 30, 2003 | 07:23 PM
lilgrebbie's Avatar
I paid $42.00 for mine from www.oxegensensors.com
Here is a diagram where it is, you can also order them from here but they are alot more expensive.
http://www.courtesyparts.com/A32_O2-sensors.html
Anyone else?
Old Nov 30, 2003 | 07:24 PM
twiggy144's Avatar
Originally Posted by lilgrebbie
lilgrebbie
That reservoir is is for the power steering fluid!!!
The fluid is the same as ATF, but it is ofr PS. There is no transmision fluid reservoir outside the transmission. All the fluid is inside the tranny.
Old Nov 30, 2003 | 07:26 PM
twiggy144's Avatar
[QUOTE=twiggy144]That reservoir is is for the power steering fluid!!!
Old Nov 30, 2003 | 07:29 PM
Jatan's Avatar
Dexron III ATF: http://www.motorvate.ca/mvp.php/702
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
rbuswell
Nov 12, 2016 04:11 PM
Slamrod
Sep 3, 2015 07:38 PM
