Lower Control Arm Install Help
Old Dec 1, 2003 | 11:31 AM
Ucffl's Avatar
97 Max GLE
Recently hit some ice and slid into a curb. From what I can see, the lower control arm on the passenger side is bent.
1. How difficult is this to replace?
2. How expensive is the part?
3. Does anyone have a step-by-step they can point me to?
Thanks for all your help!!
Old Dec 1, 2003 | 12:14 PM
MAXC's Avatar
its pretty simple but helps if you have some air tools. you'll have to remove the sway bar bolt the bolt that connects the control arm to the hub assembly, & 5 or 6 bolts that mounts to the fram or the car. 3 of them are on a small silver plate & 2 or 3 are at the end of the control arm that holds a rubber support in place. be sure to watch where you're removing bolts from cause a couple of them are different sizes
Matt93SE
May 24, 2019 02:58 PM
maxocar
Aug 21, 2015 12:57 AM
AT978
Aug 15, 2015 06:39 PM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
