Suspension Parts Replace or Reuse
Old Dec 1, 2003 | 02:28 PM
MaxWilk's Avatar
Can anyone give me an idea of the parts on the suspension to replace and which ones to reuse. I know that it is different on each car, but Courtsey quoted me $380 for the parts other than the shocks/struts. I am using the following link as a guide.
http://www.kcmaximas.org/tech/suspension/index.html
Any help is appreciated, thank you.
Old Dec 1, 2003 | 04:14 PM
2DMax's Avatar
Are you doing a swap?
I will have to dig up my receipt, but I have a list and it runs much less than that.
I just replaced the rubber parts.
Old Dec 1, 2003 | 07:07 PM
Jatan's Avatar
Replace dustboots, front strut bearings, front mounts (if yours are bad), and you can reuse everything else. Wrap your springs in vinyl tubing or wire wrap to stop the springs from making noise
Old Dec 1, 2003 | 07:34 PM
2DMax's Avatar
This was my shopping list:
(Qty) Part # Item
(2) 54329-39U00 Spacer-FR $14.44 for both
(2) 54325-5V000 Bearing-S $47.92 for both
(2) 54034-31U01 Seat-Rubb $18.34 for both
(2) 55338-0M000 Seal-Shoc $13.65 for both
Total ...............................$94.35
I purchased all the above from Garrands Nissan in Plattsburgh (over the phone).
I purchased Dust Boots seperately, and reused the things to wrap the springs.
These are part numbers for my '98, double check them for your year, should be the same.
Old Dec 1, 2003 | 08:43 PM
voltman's Avatar
Depends how many miles you have on your car.
Old Dec 2, 2003 | 07:51 AM
MaxWilk's Avatar
You have all been very helpful, thank you. The car has 125,000 on it and I'm sure it has the original suspension (bought it with 47k). The way I read it is basically to replace the rubber parts and bearings. Has anyone had problems with reusing the brackets or strut insulators? I am doing both front and rear. I want to get at least 75,000 more miles on the car and not have to touch the suspension again.
Old Dec 2, 2003 | 01:35 PM
Jatan's Avatar
Just replace what I told you in my previous post. Just keep the original spring isolators AND wrap the springs with vinyl tubing or wire wrap so they won't make noise when you drive
Old Dec 2, 2003 | 02:24 PM
MaxWilk's Avatar
Thank you, JaTaN. After looking at my list that all makes complete sense. I should have my GR2's waiting for me when I get home and I'm getting the parts from Courtsey for under $130 shipped (btoh front and rear). What would we do without the .org?
Old Dec 2, 2003 | 06:25 PM
Jatan's Avatar
Spend your modding money on repairs from the stealership
Old Dec 2, 2003 | 06:38 PM
GodsmackMAX's Avatar
so true....
KristyKarina
Aug 23, 2015 09:53 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
