HorsePowerFreaks
Old Dec 4, 2003 | 11:09 PM
Phatmax98's Avatar
HorsePowerFreaks
Hey, has anyone bought anything from this site? www.horsepowerfreaks.com Surprisingly enough, this place has a lot of stuff I've never seen before. All the turbo people need to check out this thing called a 2 Step Rev Limiter...it's located in the electronics section, I was reading about it and it says this,
"This is the genuine 2-step made and supported by Phillip Long. We are now stocking his wonderful product for immediate delivery. First thing you should know about this is that it is a sinch to install: 4 wires into your ECU & you are done. This kit comes complete with instructions that will allow you to build up to 6 PSI of boost in a stock twin turbo 6 speed car at the start line. Single turbo cars will vary but can build up to 9 PSI. This device basically does away with the need for NOS off the line. When activated, you simply hold your throttle to the floor and the 2-step rev. limiter will do the rest at the preset RPM level you choose. You can use either a hand switch or switch off the clutch pedal to disable the 2-step when you launch the car."
Oh and they have a lot of other stuff for the Max, I even saw the Stillen Y-Pipe for $225!!! That is the absolute cheapest I have ever seen it.
MplsMadMan
Sep 11, 2015 07:54 AM
93maximaguy
22
May 6, 2013 02:33 AM
GlorfyedPerformance
Oct 20, 2010 09:53 AM
po8pimp
Sep 14, 2007 03:33 PM
