Potential Problem with Car Running In Snow?
Old Dec 6, 2003 | 01:36 PM
HarrisH's Avatar
I just started up my car it's buried under a lot of snow, and I heard whine like sounds coming from the belts, nothing loud but it's audible. Sounds like water is getting into the belts or something, you know like after you wash a car and water accidently gets by the belts and you start it up its like a really loud whine. Well that's what it sounds like just that the whine isn't as loud and it's consistently making that sound.
Old Dec 6, 2003 | 05:51 PM
spreenyk888's Avatar
everything is just cold and wet, im sure when you drive it around for a few minutes and it gets a little warmer out everything will be fine
Old Dec 6, 2003 | 06:16 PM
ivelweyz
I don't see how water would damage the belts. Maybe the pulleys. I sometimes spray WD40 or some lubricant on the belts when they make noises...
Old Dec 6, 2003 | 06:20 PM
PoePoe2797's Avatar
Old Dec 6, 2003 | 06:35 PM
Frank Fontaine's Avatar
Originally Posted by PoePoe2797
Wouldn't make any sense to actually adjust the belts, would it?
Old Dec 6, 2003 | 06:50 PM
geo1317's Avatar
or get new ones? it might be time for a tune up.
Old Dec 6, 2003 | 06:56 PM
ivelweyz
Is there a problem? If you disagree say it don't just post smileys...
Old Dec 6, 2003 | 06:59 PM
PoePoe2797's Avatar
Yea I disagree with you...you dont spray lubricant on belts. They have a special belt dressing. And by the way, don't tell me how to post...if I want to post smilies, I will and you can't do anything about that
Old Dec 6, 2003 | 09:16 PM
DaBombX's Avatar
I read that WD-40 was not technically a lubricant, although used like it is.
It was intended to be a corrosion preventive.
The name WD-40 stands for "Water Displacement, 40th attempt".
Take water out and it prevents corrosion.
It think I read it at howstuffworks.com
Just thought I'd share.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
