Went to the Track last night............
Old Dec 7, 2003 | 01:06 AM
NISMOMAXMAN's Avatar
Well I finally took my car to the track for the first time. I ran 4 times, I got there really late due to someone giving me wrong directions (20mins going the wrong direction) anyhow, my first run, was against my friends maxima (96gxe ..auto, ypipes, intake, exhaust,..something else) , My car is a 96 SE..auto.. with intake and exhaust setup. This is what I ran, on D with O/D off.
Reaction: .817
I1: 2.409
I2: 6.785
I3: 10.432
MPH: 68.981
E.T. : 16.239
MPH: 83.781
Win Margin: .640
His time was...............
Reaction: .835
I1: 2.352
I2: 6.569
I3: 10.031
MPH: 71.510
E.T. : 15.581
MPH: 87.943
Win Margin: 640
I had a great time, watching camaro's, corvette's, and mustangs run 10's 11's 12's etc................My second and third run sucked.......16.327, and 16.395 <(both of these runs I upshifted from 2, then D, with O/D off)
But at my last run, I think I did a good job..... I ran 16.168 (on D with O/D off) and that was against a honda civic he hit......17.252 he jumped, and was foul, but we still went at it, he took me really bad at take off, but I caught up to him at the end just before the marker. Well what do you guys think??? I want to hit 14.5 thats my goal, no S/C or Turnbo's just pure bolt on's.... My car still needs a tune up, and I'm getting BRAND NEW y-pipes (cattman). What else do I need? I want to get a MEVI and ECU upgrade, B-pipes, Pulley, Clean out the throttle, anything else?????????? Is a good way to go?? Any recommendations would help.. Thanks alot Raul
Old Dec 7, 2003 | 03:00 AM
RastaManMax's Avatar
How many miles since last tune up... Your ET's look pretty slow... Get these AFTER tune up and pulling codes...
1) Y-pipe/B-pipe/UDP/MEVI/Weight reduction/Pathfinder TB, remove random heat shields, spare, other clutter, flootmats, jack, rear seat, if you wanna go hardcore, get a muffler, high flow cat, lightweight wheels and slicks...
With all that you should run pretty decent...
LEMAR
Old Dec 7, 2003 | 05:02 PM
My I ask what does the pathfinder TB do? How much is it? And where can I get it? (junkyard? etc...) Also I have 15's on my car, with normal tires (60/65 < something like that, there average car tires) I want to get 17's or 18's how much hp am I going to lose with these? I'm going with light weight rims...
Old Dec 7, 2003 | 05:08 PM
Ceasars Chariot's Avatar
Old Maxima Legend
good job on the runs .. !
Old Dec 7, 2003 | 06:05 PM
99Maxima5sp's Avatar
I think i read somewhere of people having leaning out issues when running a pathfinder TB. Something with the motor getting to much air and not enough fuel.
Eric
Old Dec 7, 2003 | 06:07 PM
Taken2DaMax's Avatar
Not bad on the runs. Now you have something to work for.
VI and JWT ECU are really expensive, I would leave that for last. Make you car light weight and pratice taking off. OH and mods would help too!!!
Old Dec 7, 2003 | 11:04 PM
Just a quick question, does flooring it mess up my engine? I like drive my car hard alot, not every turn nor every street, but every other now and then I'll stomp on the pedal. How bad is that? and what can I do to keep my engine in good shape?? As far as modding goes, what can I put for bolt on's??
Y-pipes <getting this December
B-pipes < getting this January
Cat Converter < getting this January
Undrive Pully < summer 04
Cattman Intake or MEVI ? < summer 04
ECU upgrade < December 04
am I missing anything??????????
Old Dec 8, 2003 | 06:42 AM
Torgus's Avatar
use the drop resistor mod at least. or buy a new VB.
Old Dec 8, 2003 | 07:10 AM
mzmtg's Avatar
Minister of Silly Walks
That's very bad. You shouldnt even floor it all the way when racing. Your engine is probably on its last legs if you treat it that way.
[/sarcasm]
Old Dec 8, 2003 | 05:02 PM
Dont waste your money on a performance cat, they usually will take a dump after awhile.
Invest in a VB mod, MEVI/ECU, intake, y-pipe, b-pipe, udp, and your all set. With that, depending on the condition of your car and track conditions that should be good for mid-low 14s...
And flooring it is fine, just dont unnecessarily rag on it all the time..
Eric
Old Dec 8, 2003 | 05:06 PM
ivelweyz
My second CARSOUND cat just crapped out after a couple months, first one crapped out after 2 weeks. POS...
Old Dec 8, 2003 | 05:17 PM
SleepyMaxxx68's Avatar
Raul whats up it's Ryan. Good job! Your reaction will get better with time don't worry.Hey, we've talked about what you need to do. But hey did you run what's-his-name. I don't remember. the first time I went to the track my reaction was pretty decent like .63-.75...took some time to get used to but hey video games help! But yeah you need to use the drop resistor mod when you're an auto. Did you let your car cool down when you got there or even between runs? Oh yeah did you turn off every thing, a/c & radio? And did you do a burn out? Helps the tires grab. Did you use an VP Fuel? I used to use some octane booster when I went put it in like before the drive up there? And did you use 93 Octane? You should. Dude change the oil to before you go next time, clean the filter, little things like that. Did you take out the spare, floormats and other weighty things? Well good luck, haven't heard form you, e-mail me sometime, Sundays Anyone?
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
