Cigarette lighter socket won't stay in...
Old Dec 10, 2003 | 01:21 AM
rwatt1981's Avatar
My cigarette lighter socket has a real problem staying still. When i use it to light up a smoke, the lighter comes out and so does the whole socket piece. I probably messed it up this summer when I was putting in my CD player. Is there a trick where it won't ever come out of the hole when i pull the lighter out?
Thanks!
Ryan
Old Dec 10, 2003 | 09:57 AM
Andy13186's Avatar
Ever since i got my CD player installed mine does that same thing too!, Its pretty damn annoying, mabe ill just superglue it in there sometime.
I dont know waht they messed up, but it sucks and is very annoying. I use it to charge my cell phone though, so i dont have to unplug it as often as you do.. but it still sucks.
If you find a solution, can you private message me pls?
thanks
Old Dec 10, 2003 | 10:41 AM
happyricefob's Avatar
V^___^V
check if you have any blown fuse. the fuse box is located under your steering wheel. i would check the 12V fuse and the cigarette fuse.
you can buy new fuses at any local auto shop.
Old Dec 10, 2003 | 11:55 AM
(_8*(l)Homer's Avatar
What are you talking about?
Old Dec 10, 2003 | 07:19 PM
boyzindahood978's Avatar
Hey! Happyricfob is right, its the fuse! (sarcastic)
Old Dec 10, 2003 | 08:40 PM
EteRnity059's Avatar
Boosted?....
Mine did the same thing. To fix it, take ou the dash trim around the shifter and pull really hard on the back of the socket till you hear a click. It just needs to be locked down again.
Old Dec 11, 2003 | 03:45 AM
apbrian112's Avatar
yup mine did that, i got away with twisting the cigg lighter or cell phone charger clockwise and it stopped popping out, but i guess eternity059's idea is much better and more permanent.
Old Dec 11, 2003 | 06:54 AM
infinitiblast's Avatar
Umph.............since when does a fuse hold the actual lighter in place?
Old Dec 11, 2003 | 06:57 AM
VQvroom's Avatar
Thanks!
Ryan
man you smoke in your car??????
id take it as a sign not to smoke in the car.
my $0.02
Old Dec 12, 2003 | 12:13 AM
rwatt1981's Avatar
my $0.02
ask any smoker if they smoke in there car, it's a smokers thing
Old Dec 12, 2003 | 12:20 AM
V^___^V
my bad didn't read carefully. good luck with your problem
Old Dec 12, 2003 | 06:53 AM
cardana24's Avatar
Blown
take two fuses from your fuse pannel and hammer one in on each side of the cig. lighter socket (kinda like a wedge on each side)....it should stay and you will have checked your fuses...j/k, please dont do that
**I have had the same problem too and I have just delt with it...I just push it back in when when it pops out
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
leatherneck
Sep 30, 2015 09:16 PM
