Sway Bars
Old Sep 19, 2000 | 11:37 AM
I relativley new to this stuff and was checking out sway bars. I understand that they attempt to reduce body roll. My question, and I can't seem to find the answer anywhere, is how exactly they (the sway bars) accomplish this.
From looking at the Stillen and Addco sway bars, it seems odd that one, the Stillen, only attaches to the swing arms, while the Addco attaches to the swing arms and to the axle. Is there an advantage either way?
Thanks,
Mitch
Old Sep 19, 2000 | 11:54 AM
ZuMBLe's Avatar
The stillen doesn't need the additional supports because the two mounts are made from a really thick and strong alloy.. The addco uses more mounts because the trailing arm mounts aren't as strong.
ZuM
Thanks,
Mitch
Old Sep 19, 2000 | 12:00 PM
ZuMBLe's Avatar
Oh BTW
The sway bar works by reducing the indepenence of the suspension.. If the right wheel moves up.. the bar will force the left wheel up.. thats as basic as it gets.. picture it in your head..
ZuM
Old Sep 19, 2000 | 03:58 PM
96BLUMAX's Avatar
What differences have you guys noticed after installing one?
Old Sep 19, 2000 | 04:09 PM
Stillnmax's Avatar
big diff even with shoddy tires ... id say at least 30-50 %
Old Sep 19, 2000 | 04:27 PM
compu_squid
I just popped on a Stillen RSB two weeks ago tremendous difference on high speed or quick turns. Car feels very flat and "leans" a lot less
Old Sep 20, 2000 | 03:39 PM
machavez702
To answer the original questions, the Stillen only mounts to the trailing arms so that the position of the sway bar can be be moved in front, under or after the axle. The Addco is not adjustable in this manner. Changing position of this bar changes the characteristics of the handling. I have moved mine from 2" past the axle to about 1/2" past the axle. It changed my ride from feeling like an oversteering car around corners to feeling like it's more neutral.
The body roll is reduced greatly because the bar connects both sides of the car together, much like an added frame member. The axle also crosses the car, but merely connects the wheels together. The Addco bar would then connect the frame, axle & the bar together. I am not sure what the effects would be to have the Addco connecting the frame to the axle???
Old Sep 20, 2000 | 06:34 PM
96BLUMAX's Avatar
What is the cheapest you have seen the stillen sway bar for?
Old Sep 21, 2000 | 06:39 AM
Stillnmax's Avatar
i got ripped off from stillen for about 170 after taxes and shipping and what not using my CC from a shop i know in albany
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
