Question for those who have installed the quaife.
Old Dec 10, 2003 | 08:34 PM
SLC98Max's Avatar
I have two questions. The first is : What is the best way to get the old differential bearing races out? Should I press in the new races or is there a way to tap in the new ones? I don't want to damage them.
The second is: In the FSM it lists various shim sizes vs dial indicator readings. For example .0201-.0217 use shim .xxxx + .xxxx. Does the plus mean I should use both of the shims listed? Basically am I supposed to order two shims for the differential bearing preload or one?
Your help is greatly appreciated!
Old Dec 10, 2003 | 09:32 PM
SLC98Max's Avatar
bump
Old Dec 11, 2003 | 12:00 PM
SLC98Max's Avatar
Does anyone have any idea?
Old Dec 11, 2003 | 12:39 PM
nismos14's Avatar
§è~® f®ÈÄk
someone will just give them some time to respond bro! good luck to ya
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
