short throw
Old Dec 12, 2003 | 12:28 AM
Guttermouf5150's Avatar
short throw
i just installed a shifter, and it hits the plastic trim piece around the shift boot. has anyone else had this problem? also it rubs on the cat. conv. heat shield. i dented it with a mallet, but not enough i guess.
Old Dec 12, 2003 | 01:21 AM
well thanks for all the input.
Old Dec 12, 2003 | 01:26 AM
NismoVQ's Avatar
What brand sts is it? I have a pacesetter. My heat shield has been removed for about 9 months now... I couldn't keep it from scraping. Never heard of the shifter hitting the plastic trim though.
Old Dec 12, 2003 | 01:32 AM
you removed your heatshield with no ill effects? i figured maybe the rubber boot around the bottom of the shifter would melt or something.
im not sure of brand, because i bought it off ebay. it looks like the courtesy nissan one that is pictured in the write-up located in the how-to's. so i believe it is that one.
yeah i have the bend going back, and it still hits the trim when i am in first, third, and fifth. feels almost like it isnt going to go into gear.
Old Dec 12, 2003 | 01:33 AM
but nothing bad has happened at all as a result of the heat shield being gone?
Old Dec 12, 2003 | 02:39 AM
NismoVQ's Avatar
I haven't had any problems. I did this after other members on this board suggested it, they had theirs removed and had no problems. I do feel the shifter get a little warm, but not hot. Also, the temperature here in hawaii is always hot. I tried denting the heat shield at first.. It wouldn't scrape at first, but it did later when the heat expanded the heat shield. So I removed it, and never had any problems.
Old Dec 12, 2003 | 08:04 PM
ok thanks for the info.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
