5spd conversion
Old Dec 12, 2003 | 12:10 PM
thelostbrian's Avatar
5spd conversion
When putting the new 5 spd tranny in.... is there any re-welding required? or it bolts right in....
also, is there anything else i should be aware of?
Old Dec 12, 2003 | 01:39 PM
Nismo's Avatar
The only thing you have to modify is that you have to cut/drill the sheetmetal in the firewall so you can bolt the clutch pedal and master cylender on since there is no hole there on automatics(theres an outline to where it supposed to be but no hole). Everything else bolts right up.
Old Dec 12, 2003 | 01:42 PM
hlh0501's Avatar
Sounds like nismo already nailed this pretty good.. only change is the cutting of a small hole in the firewall for the master cylinder to fit in. Everything else is already there and pretty straightforward.
Old Dec 12, 2003 | 03:59 PM
thanks for everything... what are all the parts that i need..
Old Dec 12, 2003 | 04:30 PM
1991tsi's Avatar
hey guys, i'm still looking for an answer on the CEL debate: is there any way I can keep my AT ECU??
Old Dec 12, 2003 | 04:54 PM
talk about thread jack!
Old Dec 12, 2003 | 05:09 PM
Nismo's Avatar
about using auto ecu- it will work and you can drive with it but you will get a ton of CEL lights since its thinking its an auto. you might get some funny Idle problems too but its still drivable.
Old Dec 12, 2003 | 06:22 PM
jdmmax's Avatar
HEHEHEHHEH i lucked out and bought the rigth ecu for my car. i have no cel lights. idles perfectly drives even better.
i just to lazy to rewire the reverse lights that is it
Old Dec 12, 2003 | 06:30 PM
glass88jaw's Avatar
to add to lostbrians question... is there a detailed list of parts and such for the conversion?
Old Dec 12, 2003 | 07:03 PM
jdmmax's Avatar
http://www.fastmaxima.com/5spd_conversion.htm
Old Dec 12, 2003 | 07:52 PM
glass88jaw's Avatar
Originally Posted by jdmmax
thanks!!!!
Old Dec 12, 2003 | 07:54 PM
Nismo's Avatar
Adding some corrections to the parts list in the above link
Only the drivers side axle you need to get(pass is the same)
No need for a new starter.
Old Dec 12, 2003 | 08:40 PM
jdmmax's Avatar
i used axels of a 2k
as well as a 2k tranny.
irvine78 has been using 97 auto axels
Old Dec 12, 2003 | 09:08 PM
thanks!!!!!!!!!!!!
Old Dec 12, 2003 | 09:58 PM
aznsap's Avatar
will '00-'01 manual trannies work with all the 4th gens? are the gear ratios the same as the 4th gen (i don't know since the engine blocks are the same but i thought the power curves were slightly different).
Old Dec 14, 2003 | 02:50 PM
aznsap's Avatar
oh ya, anybody know which parts on an 00-01 manual tranny can and can't be transferred to a 4th gen?
Calabar
Oct 5, 2015 09:57 PM
ef9
Oct 4, 2015 08:43 AM
kjlouis
Sep 14, 2015 11:22 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Hdnseek
Sep 9, 2015 05:55 AM
