97max-se Check Engine Light (ecu-0606
Old Dec 14, 2003 | 03:21 AM
2b1ask1's Avatar
Need Help (new to forum). currently located in the Uk. 2 problems- 75kmi
Problem #1
Started the car 3 days ago (weather-very cold). Car starting running very rough. Car was vibrating very bad, It just wasn't right. Check engine light came on. I pulled the code from the pcm (0606 - cylinder#3 misfire). Spark plugs was replaced in Jun.
Problem #2
Planned to investigate problem this weekend but car would not start. The engine doesn't turn. When I turn the ignition, the starter just WHINES. I pulled the code again and it remains 0606. Not sure what to do at this. Thanks
Old Dec 14, 2003 | 05:50 AM
Kevlo911's Avatar
Kevlo for President
0603 0604 0605 0606 0607 0608
If one cylinder is misfiring the problem is spark or fuel. A misfire due to a spark problem usually results in a Service Engine Soon light and one of these Diagnostic Trouble Codes:
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
You don't have any of these codes, and the engine smooths out at engine speeds greater than 1000 rpm, so let's assume the problem is with fuel delivery.
I believe one of your fuel injectors is not performing properly. There are two tests the home mechanic can make, the sound test and the resistance test.
Sound test...
This test is performed with the engine idling. Use a mechanic's
stethoscope or a length of rubber vacuum hose, and listen to each injector.
All injectors should sound alike. If you find one which makes a different
sound (or no sound at all) you have found a problem.
Resistance test...
This test is performed with the engine off. Use an ohmmeter to measure the
resistance of each injector. This does not require removing the injectors.
I don't know the correct resistance value for the injectors on your model,
but they are typically a low number such as 16 ohms. The important thing
is they should all be equal. If you find one injector with substantially
higher resistance than the others, it is bad. If you find one with zero
ohms (short circuit) that is truly unfortunate, because the injector is bad
and it may also have damaged the Engine Control Module (the computer)
because of excessive current drain.
Measuring the resistance of the front bank of cylinders is easy because the
injectors are in plain view. Disconnect the injector electrical connector
for cylinder #2, measure the resistance, reconnect the connector. Repeat
for the cylinders #4 and #6.
Measuring the resistance of the rear bank of cylinders is almost as easy,
but it is difficult to reach the injectors. The resistance may be measured
at a conveniently located electrical connector. Notice the largest,
thickest electrical harness at the top of the engine. This is the Engine
Control Harness and it is shaped like a U, with the open top of the U at the
driver's side of the car. The U has two corners. Look at the corner
nearest the passenger seat. Just inside that corner you will find an 8-pin
electrical connector. This is connector F131. Disconnect this
connector. Now look at the male part, the connector half with the pins
exposed. They are arranged in two rows of four pins.
The pins are numbered 1 - 4 (top row) and 5 - 8 (bottom row).
Measure the resistance of:
- injector #1 between pins 1 and 2.
- injector #3 between pins 1 and 6.
- injector #5 between pins 1 and 5.
Be sure to measure the PINS, not the female receptacles.
The dealer's shop is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a ohmmeter and a rubber tube.
Old Dec 14, 2003 | 07:03 AM
2b1ask1's Avatar
Problem #1
Problem #2
Thanks Kevlo911, are there "detailed" instructions available for checking/testing the ignition coils??
Old Dec 14, 2003 | 07:15 AM
Kevlo911's Avatar
Kevlo for President
With the ignition off, disconnect the electrical connector from the ignition coil. Connect the positive (+) probe of an ohmmeter to terminal no. 1 and the negative (-) probe to terminal no. 2 of the coil connector - the meter should inditcate infinite resistance. Reverse the meter leads( negative probe to terminal no. 1 and positive probe to terminal no.2) - the continutiy should be indicated, but not zero ohms. If hte results are not as specifed, replace the coil.
Connect an ohmmeter between the secondary terminal ( the one that hte spark plug connects to) and terminal no. 1 - the meter should indicate infinite resistance. If not, replace the coil.
Old Dec 14, 2003 | 07:17 AM
Kevlo911's Avatar
Kevlo for President
that was taken from the haynes manual
Old Jan 4, 2004 | 05:13 AM
2b1ask1's Avatar
97 Max Se - Check Engine Light Ecu-0606
Happy New Year, Finally received and replaced HANSHIN igniton coil on cyclinder #3. Now I'm getting ecu 0701 (multiple cyclinder misfires).
Help me please....
Old Jan 4, 2004 | 10:55 AM
95CustomMaxima's Avatar
I would check your fuel injectors.
-Nick
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
