Door stop, Dome, Key and map light not working
Hi guys I need some help I just finished ripping out my dash to put in red 194 bulbs. I also colored the little bulb in the key ring to match. I had bulbs left over so I changed the door stop bulbs to blue and I removed the dome and map light as well. I put everything back and all was well. Till I put the blue bulbs into the doorstops then the dome,map, key and door stops light didn't work. I checked the fuse box and found no blown fuses. My dash works fine ( radio, ac , clock all light,) except the lights listed above. I wont be putting the dash back till this is solved.
Any help you guys can give me would be great.
P.S. I didn't put any of the bulb condoms back on if that makes any difference.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
check them out, there is one just for the interior lights
