Technosquare or JWT ???
Old Dec 17, 2003 | 07:58 PM
matty's Avatar
Money isnt a consern I just want the Best Product..
Technosquare is $380 for an X-mas Deal (NO raised Rev- Limiter)
JWT is around $550 (WITH raised Rev limiter)
I have MEVI which raised rev limiter would be good and I dont really plan on Boosting or gettin nitrous...
what do you think ??
Old Dec 17, 2003 | 08:01 PM
MaxedOutOfCash's Avatar
Pizda Boy
Is it even a question? Get the JWT otherwise the MEVI is pointless.
Old Dec 17, 2003 | 08:29 PM
Nealoc187's Avatar
SLOW
You shouldn't even be asking this question. JWT.
Old Dec 17, 2003 | 10:02 PM
nismology's Avatar
I think you should hold out a little bit longer for the Technosquare ECU with raised limiter. IIRC, Deezo sent one to them and they are working on cracking it.
Old Dec 17, 2003 | 10:03 PM
meccanoble's Avatar
Sports Button FTW
i hope it happens, i really do
Old Dec 17, 2003 | 10:40 PM
BEJAY1's Avatar
Conecarver
Cheston? You around? Sorry I couldn't make it down to Torrance and catch you guys.
Old Dec 17, 2003 | 10:44 PM
Max1man's Avatar
Ya there's really no contest....MEVI+JWT is the golden apple. Of course...boost on top of that is the worm that 0wnz yer apple
Old Dec 18, 2003 | 06:16 AM
Ceasars Chariot's Avatar
Old Maxima Legend
jwt
Old Dec 18, 2003 | 08:45 AM
JMAXIMA's Avatar
what about w/o a MEVI?
Old Dec 18, 2003 | 10:15 AM
97blackSE's Avatar
you dont need an ecu unless you have/plan on getting mevi...
JWT!
Old Dec 18, 2003 | 11:31 AM
nismology's Avatar
JWT!
That makes absolutely no sense...Care to rephrase?? There ARE other things an aftermarket ECU does other than raise the rev-limiter...
Old Dec 18, 2003 | 12:42 PM
97blackSE's Avatar
Yea Sorry I was tired... If you really are expecting huge gains from an ecu, the only way you will see it is with a mevi, where you can get the top end that the mevi wants to give, thanks to the new rev limiter. An ecu alone just changes your fuel mapping to something more aggressive, giving you what, 10 hp by it self? Not exactly a cost effective addition without a MEVI...
Better mang?
Old Dec 18, 2003 | 01:14 PM
nismology's Avatar
Well it also does offer a more aggressive ignition timing map, and more importantly, it offers gain throughout the powerband. Most of the guys with JWT/MEVI said if they could do it over again, they would get the ECU first.
Old Dec 18, 2003 | 01:28 PM
JMAXIMA's Avatar
::Most of the guys with JWT/MEVI said if they could do it over again, they would get the ECU first::
i read that recently... and thats why i was asking. i'm not really looking for the gains of a MEVI... and i don't want to mess with nitrous... i just want a simple bolt on to add some power accross the powerband. will the technosquare be as benificial as the JWT w/o a MEVI?
Old Dec 18, 2003 | 03:01 PM
michaelnyden's Avatar
no it won't according to all the dynos and butt dynos out there, while they are very close, JWT squeezes more power out of your engines by simply revving higher, a trick honda has been using for years, the easy way to get more power if you ask me....according to all the stories, w/o the mevi, the technosquare gives slightly higher and smoother gains and is cheaper rpm for rpm without raising the rev limiter, personally if you don't have the mevi, save some money and get a better ecu as well--technosquare, use the left over money and buy another power gaining item instead! plus with technosquare i here you will get your ecu very fast instead of a month like JWT! any way, good luck!
Old Dec 18, 2003 | 03:51 PM
Jason R's Avatar
aka UNCDooD
I plan on getting the JWT ECU soon and then I will get the MEVI. I can't wait to hear my VQ wind out to 7k rpms.
Old Dec 18, 2003 | 04:16 PM
Max1man's Avatar
Or even 7200 I know the stories about some people experiencing valve float at 7200 but I figure might as well go with the max I can get and save those extra 200rpm for hon-duh spankins
Old Dec 18, 2003 | 04:19 PM
nismology's Avatar
WTF?? The easiest way to get more power is by revving higher?? The Technosquare gives smoother gains?? It's cheaper RPM for RPM??
Man your whole post doesn't make sense. Maybe I read it wrong. Not trying to flame but what are you trying to say??
Old Dec 18, 2003 | 04:47 PM
JMAXIMA's Avatar
IwANnAMaX96
what is your input on my question... w/o a MEVI, is the technosquare as good as the JWT?
Old Dec 18, 2003 | 04:57 PM
nismology's Avatar
I'll say this...With the possibilty of the Technosqare ECU with the raised rev-limiter pending, there would really be no justifiable reason to get the JWT ECU, MEVI or not, unless you aren't willing to wait for the TS w/raised limiter. But since you're not planning on a MEVI, the answer is simple IMO. Are you willing to spend over $150 more and have a longer turnaround time?... Caesar's Chariot ran a 14.3 with intake, full exhaust, pulley and Technosquare ECU...
Old Dec 18, 2003 | 05:04 PM
JMAXIMA's Avatar
fair enough
Old Dec 18, 2003 | 05:17 PM
matty's Avatar
I think JWT is alot better of a name for $150 i think its worth getting the JWT...maybe down the road a few months youll run into a MEVI for cheap then you wont have go switing to a JWT and losing alot of money
-matt
Old Dec 18, 2003 | 08:32 PM
krismax's Avatar
Father of the 00 VI
It will sound even better at 7600rpm
Old Dec 18, 2003 | 08:44 PM
Titan14's Avatar
what is technosquares website??
Old Dec 18, 2003 | 09:05 PM
Dave B's Avatar
Not DAVEB the parts guy
3 years ago "Jeff K" ran a 14.3@96mph with a high 2.2 60' with his 96 SE, no gutting of the interior (Caesar yanked all his seats), CAI, y-pipe, JWT ECU, and UDP. Just something to consider because Jeff did this with a JWT ECU 3 years ago and with more weight and a far worse 60'.
If you have ANY plans to get an MEVI you would be absolutely stupid to get the Technosquare ECU. Also the 7000rpm limiter actually helps out the stock manifold setup in that ~6700-6800rpms on the 1-2 shift is actually ideal. All ideal shift points thereafter are below 6500rpms, but it does help that 1-2.
Dave
Old Dec 19, 2003 | 05:42 AM
Max1man's Avatar
Wouldn't getting the TCU upgrade improve the shift points? Reason I ask is that I'm considering doing that to but there's not a lot of info on what the TCU upgrade gains you out there.
Anyone care to elaborate?
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
Mahmuth
Sep 25, 2015 10:08 AM
Slamrod
Sep 3, 2015 07:38 PM
