Exhaust help please 911 Fart can NOOOOOOOOOOOO
Old Dec 21, 2003 | 12:46 PM
alexg240's Avatar
I just had a warpspeed y pipe carsound cat and resonated warpseed b pipe installed with a magnaflow 14829 street series muffler. THe problem is that the exhsut is not deep at all it sounds farty arround 3500 rpm and when i step on it the exhaust gives off a farty sound. How long does it usually take for an exhsut to break in and get a deeper sound> i had the exahsut on for 4 days and have driven 700 miles the sound has changed a little , should I expect more of a change and if so how long does it usually take.
Old Dec 21, 2003 | 01:01 PM
Ramius83
It won't change much lol. I can jsut hear your car now lol by the way you explain it.
The only thing you can try to do is try another muffler.
Old Dec 21, 2003 | 01:27 PM
skiboarder72's Avatar
this is everyones worst nightmare someone smart help him out!!
Old Dec 21, 2003 | 02:22 PM
maxspeed96CT's Avatar
The original VQ...
all i can say is its your muffler, i got the same set up but with a dual 2.5 tip muffler and everyone i talked to says mines sounds nice.
Old Dec 21, 2003 | 03:24 PM
Ramius83
Ummm, what I mentioned was the only smart thing to do. That Warpedspeed y-pipe, cat, and Warpedspeed resonated b-pipe have been proven to provide a nice deep tone, with the right muffler. The only thing he can do is change th muffler out, as I mentioned on the first post. I am smart, thank you.
Old Dec 21, 2003 | 03:51 PM
DaThrillr's Avatar
what cat-back exhaust offers the quietest sound.... and whihc has the largest resonator?
bc my exhaust is loud and annoying at times..
Old Dec 21, 2003 | 04:29 PM
ch13f's Avatar
^ Apexi is pretty quiet supposedly.. also the OBX. If you want to quiet the exhaust down the best thing would probably be to get a 2002/3 muffler and have it welded on. You shouldn't loose much flow at all.
Old Dec 21, 2003 | 05:46 PM
soulchild's Avatar
Same thing he said. I just got a Magnaflow muffler put on my car a couple off days ago along with custom piping and it has a nice deep sound to it.
Old Dec 21, 2003 | 06:19 PM
Dave B's Avatar
Not DAVEB the parts guy
The only "quiet" setup with a Y-pipe and B-pipe is the OEM muffler or the 2000+ muffler. PERIOD. I've got a 2K+ muffler on my 96 with a y-pipe and the sound is great. The 2K+ muffler is slightly throatier than the OEM 4th gen muffler.
Dave
Old Dec 21, 2003 | 08:16 PM
Js97MAXSE's Avatar
Dave B, was there any trouble with the newer muffler or did it just fit right up to the rest of the exhaust?
Old Dec 21, 2003 | 08:30 PM
ToYLeT902's Avatar
JET Speed Lab
get a apexi ws, or greddy catback.
Old Dec 22, 2003 | 08:35 AM
Dave B's Avatar
The 2K muffler uses the stock hangars. All that's required to fit the muffler is about 10 minutes at a muffler shop.
Dave
Old Dec 22, 2003 | 08:37 AM
gabex's Avatar
DaveB, how did you get your 2k muffler to line up with the bumper hole? Mine is to the left a few inches..
Old Dec 22, 2003 | 12:29 PM
Torgus's Avatar
budget y, 2.5 B, stock cat, magnaflow, resonator
sounds mean. scares old ladies.
with out the resonator it was so damn loud.
Old Dec 22, 2003 | 01:06 PM
2k3TitaniumSe's Avatar
Get a powertech 1011 now. Not ricey at all and has a nice DEEEEEEEP sound! LOL
Old Dec 22, 2003 | 03:21 PM
Js97MAXSE's Avatar
[QUOTE=Dave B]The 2K muffler uses the stock hangars. All that's required to fit the muffler is about 10 minutes at a muffler shop.
well i do all my own work at school in my autos class and have changed a few mufflers and a few cat-backs, so will i be able to just bolt it up myself?
Old Dec 22, 2003 | 03:36 PM
gabex's Avatar
Js97MAXSE - It is not bolt-on. You have to cut & weld. To make mine fit, they cut the 2k muffler pipe totally off, and welded on the pipe from my stock muffler.
Old Dec 22, 2003 | 03:57 PM
Js97MAXSE's Avatar
well, not actually bolt on but U-clamps that are threaded at each end and you put the small end pipe into the big end pipe and tighten down to connect the 2 pipes together, you know what i mean.
Old Dec 22, 2003 | 04:05 PM
The original VQ...
this maybe helpless but what ever you do , don't put a y-pipe ,high flow cat and b-pipe on with the stock 4thgen muffler. I had this for about a week and i switched it because the sound was so bad. It was like a bad putter sound, your best bet is to go with a 2k muffler.
Old Dec 22, 2003 | 05:22 PM
DaThrillr's Avatar
what B-pipe do u suggest i use if i put on a 2k mufler... i want my car quiet like sleeper status...
Old Dec 22, 2003 | 06:06 PM
happyricefob's Avatar
V^___^V
weird. i have warpspeed y-pipe + 14829 magnaflow muffler street series. no fart sound at all. it sounds more like a domestic V8 stock exhaust system.
double check for any leakage between each exhaust component. also, are you using exhaust gasket?
Old Dec 23, 2003 | 03:07 AM
Momaxima's Avatar
hey happyricefob, did you install the magnaflow muffler urself or did you get shop to do it..and if so was the install simple?
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
