Car hesitates when starting up.
When I turn the key, the car starts coughing a little then eventually starts up. Always on first crank, so I don't think it's the starter. I'm not entirely sure, but could it be that I'm running 10W30 in sub-zero temps? Someone suggested cleaning the throttle body, which I'm going to do. But do you guys think there's anything else I should check?
The same thing is happeneing to my car. I just replaced the starter and ignition coils, so that's not the problem. It sees like it's not getting fuel. This morning it tok me 2 or 3 times to crank over. It only happens on cold mornings, so I dunno how concerned I should be. How many miles does your car have on it? Mine has 63k.
70k exact same problem, i find it works the best if you turn the key and give it some gas, i usually rev up to around 4grand and then it wont turn off on me. when i dont do that it revs to about 1500 and then cuts off, makes a weird noise 2.
What's the part # for the cts?
AllData gives me: 2263044B20
But, when I go to www.nissanparts.cc, the description is: Engine Coolant
I don't want to buy a jug of engine coolant. :-/
Originally Posted by wariow
mine makes a weird noise when starting but doesn't hesitate. The noise is a loud high pitched grinding of some kind, it sounds kinda scary but it goes away in warmer weather.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
