Cant search, transmissions problems
Old Dec 23, 2003 | 11:58 AM
twankz's Avatar
I have a 96 I30 and sometimes it will drive and sometimes the car will not move when it is in gear.
Is this a major repair job?
Would I need to get a whole new transmission?
Will a Maxima transmission work?
Old Dec 23, 2003 | 10:14 PM
BadKarma99-4spd's Avatar
im assuming you have an auto
FIRST THINGS FIRST CHECK YOUR TRANNY FLUID LEVEL
if you give it some gas dose it jerk into gear?
how often does it happen?
have you run the transmission diagnostic test in the haynes manual?
give me more info, miles, driving style, 1st owner-2nd owner-3rd?
if you car is not moving when in drive, they call this neutralizing, then your tranny is loseing pressure which probably means you have a bad gasket(.50 part 300 labor) when they got mine down they found that heat had fried the tranny and i needed a rebuild(i let mine neutralize for a month, dont do this)
a maxima tranny should work
good luck
Old Dec 26, 2003 | 12:22 PM
twankz's Avatar
Thanks for the reply!
Yes, it was jerking into gear.
It was happening all the time.
However it was taken care of, the mechanic said that there was a lot of water in the tranny, which is true because a month ago when it was flooding I went through a lot of high water. Then he said I will eventually need to get it rebuilt.
Old Dec 29, 2003 | 04:41 PM
largestal's Avatar
oops and ouch. Sorry to hear that.
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
Maxima30
Sep 7, 2015 06:13 PM
