Intake installed (check engine light on)
Old Dec 24, 2003 | 07:53 AM
MaxAttack's Avatar
Intake problem (check engine light)
Just yesterday i installed my intake. I bought a frankencar midpipe with a cone filter. I knew basically what i was doing but didnt know what one wire was. So i started looking through the .org and found this website.
http://www.brianv.net/mods/filter/
I read through and saw that i did everything right step by step. It was the 2nd picture from the bottom i saw what i was looking for.
"Now you'll find a plug that does not have anything to plug into. Inside the air box you'll see a sensor. You need to remove that sensor by unscrewing the two small Phillip's screws. Once the piece is removed you can attach the connectors together and leave the piece dangling in the engine bay. I'm pretty sure it is just an air temperature sensor. Thus, it will get a semi-accurate read by just being in the engine bay. I used tie-wraps to prevent it from moving."
BINGO! That extra plug that didnt go anywhere. That was my question. So i just tied it with tie-wraps. I went for a test drive around the block and everything was fine. I pushed it like 5 times just b/c it sounds amazing. Then Today when i started my car the check engine light is on. I went back and found 1 of the senors wasnt pushed in all the way. So i fixed everything and it is still on. Has anyone had check engine light come on after installing a intake? What should I do?
Please Help
Old Dec 24, 2003 | 07:55 AM
MaxAttack's Avatar
Please Help
Old Dec 24, 2003 | 08:30 AM
Flava_24/7's Avatar
Boosted Panda
Please Help
Anytime you start the motor without that sensor plugged in it will trigger a CEL.
Now that its plugged back in, reset the ecu. Might want to check for any other codes on the ecu as well. If you dont know how to reset the ecu, read the FAQs.
Old Dec 24, 2003 | 08:35 AM
MaxAttack's Avatar
Yeah i will need to do that....Where did yall put the temp senor?
Old Dec 24, 2003 | 08:48 AM
my99maxisnice's Avatar
damn one post is enough man
Old Dec 24, 2003 | 08:53 AM
optimus310's Avatar
wow! talk about Post *****.
Old Dec 24, 2003 | 09:22 AM
silvermax2k2's Avatar
He has 5 threads going on!
Old Dec 24, 2003 | 09:38 AM
Taken2DaMax's Avatar
try reseting the ECU. Look on the stickys on the top of the forum on how to do this.
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
