Torque on knock sensor
Old Dec 27, 2003 | 07:01 AM
palaman's Avatar
I have looked at the recent posts on knock sensors and they mentioned different foot-lbs values. I think one said 60 ft-lbs but the motorvate article says 15-20 ft-lbs. Which is right?
I guess the more important question is ... without a torque wrench what is a good rule of thumb on how how to tighten the bolt to the appropriate tightness?
Old Dec 27, 2003 | 07:26 PM
Nismo's Avatar
15-20 seems more like it. 60 is alot of torque on something like that
Old Dec 27, 2003 | 09:29 PM
Stephen Max's Avatar
I agree. 60 ft-lbs will snap that puppy.
Old Dec 28, 2003 | 08:47 AM
twiggy144's Avatar
If you torque the ks with a universal joint and an extension inclined say at 60 deg, torquing measurement gets a little more complicated.
With a 60 deg incline, the actual torque transmitted to the ks bolt will be 60 ft-lbs x cos(60 deg) = 60 x 0,5 = 30 ft lbs. I estimate the angle of the extension bar at 60 deg measured from a vertical posotion, when reaching the ks with a extension and universal joint.
Old Dec 28, 2003 | 08:53 AM
billfromtr's Avatar
torque it till it breaks and than back off a quarter turn.
Old Dec 28, 2003 | 09:06 AM
The FSM agrees with motorvate. 15-20 ft-lbs. Since you can't really get a torque wrench in there without removing the lower intake manifold, just get it good and tight by hand with a small 12mm wrench and you'll be fine.
Old Dec 28, 2003 | 10:48 AM
Nismo's Avatar
I bet thats what nissan did from the factory. might explain all these bad KS we all get
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
