Need Help!! Code 0201
Old Dec 30, 2003 | 11:11 PM
jcy98maxse's Avatar
Turbo is too much fun!
I threw a 0201 code which is the primary ignition signal circuit fault. I have already replace my coil packs and ecu but my car is not starting. I know I am getting both soark and fuel, it also cranks over pretty fast but I can see my camshaft turning. ANy ideas what it could be? I also have order a new iginition condenser which I have no clue what it does but I am desperate and it was cheap. any input would be greatly appreciated.
Old Dec 31, 2003 | 05:48 AM
Kevlo911's Avatar
Kevlo for President
0201
Diagnostic Trouble Code 0201 indicates a problem with the ignition coil and power transistor. The ignition signal from the Engine Control Module is sent to and amplified by the power transistor. The power transistor turns on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil secondary circuit.
The malfunction is detected when the ignition signal in the primary circuit is not entered during engine cranking or running.
The items to check include
- Harness or connectors (the ignition primary circuit is open or shorted.)
- Power transistor unit built into ignition coil
- Condenser
- Crankshaft Position Sensor (REF)
- Crankshaft Position Sensor (REF) circuit
A misfire on any individual cylinder should set a code, and a problem with the CPS should also set a code.
I would have expected to see DTC 0201 along with one of the following DTCs.
0407 - Crankshaft Position Sensor (REF)
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
You didn't get one of these "companion" DTCs, and that is puzzling. Maybe one of them will show up in the next few days.
Old Dec 31, 2003 | 08:41 PM
jcy98maxse's Avatar
well the CPS was checked out by the dealership, they said that it was ok, I have ordered the condenser and see if that would help.
Old Jan 1, 2004 | 06:56 AM
JAY25's Avatar
Check your codes again and see if it pin points which cylinder it is, 06??, same thing happened to me. My was cylinder number 1.
Old Jan 1, 2004 | 07:18 AM
twiggy144's Avatar
Kevlo911,
What a great write-up! I wil save this. Thanks
Old Jan 1, 2004 | 07:28 AM
Kevlo911's Avatar
Kevlo for President
most of hte ecu codes can be found in my sig. under the ecu codes defined.doc
and in the 3rd link in the sticky "help my check engine light is on"
Old Jan 1, 2004 | 12:43 PM
jcy98maxse's Avatar
None of the other codes have went off yet. I am still only getting the 0201
Old Jan 6, 2004 | 12:19 AM
jcy98maxse's Avatar
Well the condenser didn't improve the problem. My car still doesn't start, I'm running out of ideas. Everytime that I crank it over, it turns over and I can hear it sputter slightly from my exhaust like its almost going to start. I haven't gotten any "companion" codes, all I'm getting is 0201. So far I know that my original set of coil packs are fried (cuz I tested them against the ones I have now and those don't put out a spark) and I have replaced the ignition condenser and also the ecu (direct swap from a another 98). The only other thing that I can come up with its that maybe my engine wiring harness is bad, since both my ecu and coil packs were fried maybe my wires in the harness are gone too? But why am I still able to get spark to the plugs then?
I think i may have to take the car to the dealership but I am afraid they won't even be able to find the problem plus they'll probably charge me a lot of money to find the problem let alone fix it, but before then maybe one of you guys know something else that I haven't figured out.
Kevlo- what harness are you talking about in post #2? Is that the engine wiring harness or something different?
Old Jan 6, 2004 | 07:38 AM
Kevlo911's Avatar
Kevlo for President
that is probily why the car will not start. Check/Clean/Replace the sensor.
Did you check the harness/connectos for hte ignition coils and power transistor?
Old Jan 6, 2004 | 11:22 AM
jcy98maxse's Avatar
how do I check the harness and where is the power transistor located? I know I can replace the CPS from the dealership but what about the circuit? Sorry for all the questions.
Old Jan 6, 2004 | 02:00 PM
Kevlo911's Avatar
Kevlo for President
Do you have a Haynes manual? If so, turn to section 5-7. it should help alot.
if not, you can try to use the online Chiltons manual and look for ignition system check.
Old Jan 6, 2004 | 02:02 PM
Kevlo911's Avatar
Kevlo for President
the link for hte online Chilton manual is in the FAQ's
Old Mar 25, 2021 | 01:28 PM
Shannon and Ian's Avatar
Originally Posted by Kevlo911
0201
- Condenser
This is exactly what I have now .0201 and 0607. I am changing the #2 cylinder coil pack. Original Coil for 270K. What a useful old thread
Cashj2002
Aug 31, 2005 07:32 AM
drivinmax
May 29, 2005 09:31 PM
Maxima95Tuner
Feb 3, 2004 06:42 PM
outsider
Sep 28, 2003 06:21 PM
