hard starting on incline
Old Mar 2, 2001 | 10:13 AM
victor.com's Avatar
I have a 95 SE, Auto, 100K miles. Lately when I have been parking my Max in the driveway facing upward, I have a hard time starting it in the morning. The temps have been on the cold side lately, 25-35 degrees. I have not encountered this problem if I back into my driveway. Coincidence? It cranks fine, but just wont start unless I press the gas a little. I just put some fuel injector cleaner in the current tank of gas. First time using cleaner since I owned it, 40K miles. Anyone have a clue as to what might be the problem? Driveway is not that steep, fairly normal grade.
Thanks,
Old Mar 2, 2001 | 10:35 AM
Daniel B. Martin's Avatar
Thanks,
Perhaps the fuel rail lost its residual pressure due to a leaky fuel pump check valve. Next time you park facing upward, try this experiment. Turn the ignition key to ON, wait 15 seconds, then turn the key to START. This brief delay gives the fuel pump some time to fill the fuel rail and build normal pressure. If your car starts readily and runs well after this brief delay, that will confirm this fuel pressure hypothesis.
Old Mar 2, 2001 | 11:30 AM
bigtexan7's Avatar
The Maxima's in-tank fuel pump assembly is located right at in the front of the tank. If there's about 1/4 or less gas, it will do this. back the car in and you will notice a difference. I did.
captchaos
Mar 15, 2016 12:18 PM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
