Can't diag ecu
Old Jan 3, 2004 | 03:03 PM
arnelv's Avatar
Can't diag ecu
hey i am having problems with diagnosing the ecu. i followed the instructions on one of the threads, but when i try to turn the screw clockwise, the screwdriver is not gripping on anything. there doesnt seem to be anything there except a hole. from what i hear, this seems to be a pretty routine job. is the screw deep or is it right in the front. any help will be appreciated...
Old Jan 3, 2004 | 03:13 PM
aznprid972's Avatar
go here http://vbxmaxima.8m.com/ecu.html
Old Jan 3, 2004 | 06:27 PM
Eric425's Avatar
You're probably just jamming the screwdriver into some random hole. You should be able to see the screw. It's the shiny thing right next to the writing on the sticker.
Old Jan 3, 2004 | 06:35 PM
Bmr4life's Avatar
try pushing the gas pedal in so you can get a straighter line coming in to the screw and also use a flashlight so you can see what your doing. It also helps if you just lie your stomach down on the sideskirt and crawl to it. Sounds like a lot, but it'll get you the readings.
Old Jan 3, 2004 | 09:15 PM
arnelv's Avatar
well, if you look at the link where it has the instructions to diag the ecu, mine looks just like a hole...i dont see any screw there...anyways, i will try again tomorrow morning,,,thanks for all your help...btw do you know how much a mechanic will charge to do it. does autozone or any of those est do it for free...thanks again
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
pktaske
May 6, 2016 07:49 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
pktaske
Sep 4, 2015 08:40 AM
