diagrams on how to install alarm/remote start
i will be getting my new alarm remote start in this week and i wanted to instal my self i wanted to know if anybody has or know where i can find the scmatics/diagram on the wires so i konw which wires to hook up to what when i instal the alarm
Good chart, Tyrexx, but I have a couple comments. The wires change color at a plug behind the ignition harness, so make sure you're on the right side if you're just matching colors. Also, isn't the UNLOCK the double pulse, not the LOCK? Here's a different chart I found, and it helped a lot when I installed mine. Let me know if you have any questions.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|wht/red - wht/pur *6|+ |ignition harness |
| STARTER|blk/yel - blk/wht *6|+ |ignition harness |
| SECOND STARTER|grn/blk - red/blu *6|+ |ignition harness |
| IGNITION|blk/wht - blk/red *6|+ |ignition harness |
| ACCESSORY|red/yel - red *6 |+ |ignition harness |
| SECOND ACCESSORY|blue - wht/blu *6 |+ |ignition harness |
| POWER LOCK|lt. green/red |- |in drivers door at switch |
| POWER UNLOCK|green/yellow *1 |- |in drivers door at switch |
| LOCK MOTOR|brown/white | |in drivers door at switch |
| UNLOCK MOTOR|brown | |in drivers door at switch |
| DISARM DEFEAT|brown | |in passenger door at switch |
| PARKING LIGHTS +|red/green | |steering column |
| HEADLIGHTS|gry/yel(L)blu/blk(R)|+ |steering column |
| DOOR TRIGGER|red/white |- |low in drivers kick |
| TRUNK/HATCH PIN|purple/yellow |- |drivers kick or BCM *2 |
| HOOD PIN|yellow/black |- |BCM *2 |
|TRNK/HTCH RELEASE|purple/yellow |- |low drivers kick *3 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| DISARM NO UNLOCK|*4 | | |
| TACHOMETER|white/green | |ECM *5 |
| BRAKE WIRE|red/green |+ |at brake switch |
| HORN TRIGGER|green/white |- | |
| WIPERS|lt. green/red |- |steering column |
| LF WINDOW UP/DN|blu/red - blu/blk |A |in LF door at switch |
| RF WINDOW UP/DN|blu/red - blu/blk |A |in RF door at switch |
| LR WINDOW UP/DN|blu/red - blu/blk |A |in LR door at switch |
| RR WINDOW UP/DN|blu/red - blu/blk |A |in RR door at switch |
Notes:
*1 Requires a double pulse. *2 The BCM (body control module) is located just below the radio. *3 Must use a relay to interface with this circuit. *4 A single negative pulse to the unlock wire will disarm without unlocking. *5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left. *6 The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
Notes:
one quick question on this, i know this is an old topic and i may not get any responses but its worth a shot. anyway i was wiring up my autoloc stellar alaram the other day and i got to the door locks, i got the lock function working but the unlock requires a double pulse, how do i go about gettin it to double pulse?
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
