changing knock sensor: having problem understanding the last part of motorvate.ca....
http://www.motorvate.ca/mvp.php/507
pardon my poor chinglish, but what does it mean "lightly sand the connector on the wires and the flat area on the intake manifold"????
Originally Posted by motorvate.ca v2.0
The knock sensor is grounded by these two 10 mm bolts. Remove them, lightly sand the connector on the wires and the flat area on the intake manifold, then tighten the two bolts. This will remove any corrosion.
lol..cake.. just unscrew those bolts.. get a towel and some carb cleaner to clean the area around the bolt, clean the contact on the bolt while your at it.. sand it if you want..he just means sand the area wher the bolt touches the intake manifold. and the area on the bolt itself. then put it back on..
its just a ground. the knock sensor is grounded there. if the contact is dirty/greasy, it will not ground correctly and your knock sensor will not funciton properly..
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
RealityCheck
Aug 5, 2015 06:18 AM
