help!! just changed front 02 sensor
Old Jan 6, 2004 | 10:34 AM
maxspeed96CT's Avatar
The original VQ...
ok , a few weeks back i was gettin codes for knock sensor and front 02 sensor. I changed the 02 sensor today and now im gtetting the code for Upstream oxygen sensor heater fault(right bank) witch one is this, is it the same one i just changed or is it something diffrent?, i need help please!!
Old Jan 6, 2004 | 10:41 AM
Jatan's Avatar
This is the one by the passenger firewall. It's near the oil pressure switch. This is NOT the one by the radiator.
Old Jan 6, 2004 | 10:44 AM
The original VQ...
im not to fimiliar with these things, can you be more spacific?, and how much is this gona cost me?
is the second sensor in the y-pipe or is this not a sensor at all but some sensor heater thing???
Old Jan 6, 2004 | 12:01 PM
The original VQ...
free bump to self
just went for a ride and checked codes and knock sensor code is back!!. Can the knock sensor be causeing the o2 sensor code?
Old Jan 6, 2004 | 12:04 PM
DAVE Sz's Avatar
Hooooooonda.....
No. If you replaced the O2 sensor then you know where the plug goes. Or did you just solder in the new sensor? Check the connection. You probably just need to change the other sensor.
Old Jan 6, 2004 | 12:12 PM
The original VQ...
wel i called the dealer ship and they guy said i changed the correct one. I double checked all the connections and plugs to.
The Upstream oxygen sensor heater fault(right bank) is the senser closest to the front of the car, correct??
Old Jan 6, 2004 | 12:25 PM
DAVE Sz's Avatar
Hooooooonda.....
i believe so.
Old Jan 6, 2004 | 12:36 PM
troopermccue's Avatar
check it...
Maxima O2 sensor diagram
Old Jan 6, 2004 | 12:41 PM
DAVE Sz's Avatar
Hooooooonda.....
that doesn't even help a bit.
Old Jan 6, 2004 | 01:04 PM
Jatan's Avatar
Like I said, the one you changed is NOT the correct one. If you look on this link http://www.courtesyparts.com/A32_O2-sensors.html the one closest to the front (near the radiator) is the LEFT sensor. The RIGHT bank sensor is the one by the oil pressure switch, http://www.motorvate.ca/mvp.php/514 (near the oil filter area)
Old Jan 6, 2004 | 01:05 PM
Jatan's Avatar
Yes it does. It tells you which one is the LH (Left Hand) side and the RH (Right Hand) side
Old Jan 6, 2004 | 01:07 PM
DAVE Sz's Avatar
Hooooooonda.....
yeah, that helps A LOT.
Old Jan 6, 2004 | 06:27 PM
The original VQ...
thanks guys but i wish i new this earlier ,
kindoff a dumb question but are the sensors interchangeable sense the one i changed isn't borken.
Old Jan 6, 2004 | 07:03 PM
twiggy144's Avatar
if the part number on the diagram is the same, obviously they are interchangeable.
Old Jan 6, 2004 | 07:04 PM
The original VQ...
nope the last diget is a 8 on one and a 9 on the other, im gona try to rig something up tho sense i got nuthin to loose.
Old Jan 6, 2004 | 07:07 PM
twiggy144's Avatar
I just looked and the numbers are different. I suspect the difference is in the length of the wire, or in the shape of the connector . Be prepared to splice the wires.
Old Jan 6, 2004 | 07:12 PM
Jatan's Avatar
The sensors are the same (look on http://www.oxygensensors.com), the only difference is the length of the wire. The ones you buy from a Nissan dealer have a perfect length so the wire isn't dragging somewhere. One wire is shorter than the other (so 2 different part numbers). The ones you buy from http://www.oxygensensors.com are the ones with the long wire so they would fit in both places (one wire might be dragging, not sure)
Old Jan 6, 2004 | 07:17 PM
The original VQ...
ya thats what i kinda figured, tomoro im gona spice the wires with the broken one with the sensor i took out today sense it is still good. I realy got nuthing to loose cause the sensor i have is usless and the one in the car is broken.
Old Jan 6, 2004 | 07:18 PM
twiggy144's Avatar
a simple tie wrap will take care of the wire hanging loose
Old Jan 6, 2004 | 07:42 PM
The original VQ...
draging is the least of my worries. I just want the code to go away.
Old Jan 7, 2004 | 02:02 PM
The original VQ...
****UPDATE*****
ok , i changed the sensor today without even having to do any spilcing and everything fit perfect. Problem is im still getting the same codes for the right bank sensor and the knock sensor. So now im thinkin my knock sensor is causing both codes.
Also i have an air fuel gauge, it used to bounce around, now it stays at stoich and goes to lean at high rpms. is this normal?
Old Jan 7, 2004 | 02:27 PM
Jatan's Avatar
After you replaced the sensor, did you reset the CEL?
Old Jan 7, 2004 | 03:32 PM
The original VQ...
Yup, then i went for a ride and did it again and its still throwin codes.
Old Jan 7, 2004 | 03:39 PM
97blackSE's Avatar
Dude, do you need me to come to your HOUSE and fix this ish? Its not hard, it costs 60 bucks to change an o2 sensor...I EVEN Have an EXTRA OEM sensor for you... Let me know if you need help
Old Jan 7, 2004 | 04:40 PM
Eric425's Avatar
You replaced the one halfway down the y pipe, not the one closest to the front of the car, right? You didn't bust the sensor installing it, did you? I once sprayed WD40 on a 02 sensor trying to screw it in, and I think that screwed it up? There were no visible signs of damage, but I kept getting the code. I bought a new sensor, installed it with antiseize, and that fixed it.
Old Jan 7, 2004 | 06:59 PM
The original VQ...
no i changed the right one, it did bang around on the floor alittle but i dont think it messed it up, alot of people are tellin me its cause of my knock sensor.Cause im getting both codes. So im gona have kyle help me change it and hopefully all my codes wil go away.
Old Jan 7, 2004 | 07:02 PM
The original VQ...
The other thing is my friend said my air fuel gage is werking correctly. it stays at stoich and goes to lean at high rpm, is this how its suposesed to be?
Old Jan 7, 2004 | 07:16 PM
97blackSE's Avatar
thos a.f gauges suck... PERIOD
Old Jan 7, 2004 | 07:36 PM
The original VQ...
Ya i know, i only got it cause i got it for real cheap with the pod. Its sad i dont how it works yet.
Old Jan 7, 2004 | 08:09 PM
Jatan's Avatar
Make sure you have premium fuel in your tank and do the knock sensor resistor mod and see if that solves your problem. If it does, then your KS is bad. If it doesn't, then the KS is still good and there might still be a problem with the O2 sensor.
Old Jan 7, 2004 | 08:51 PM
nismology's Avatar
If it doesn't come with its own wide-band O2 sensor it is USELESS...
Old Jan 9, 2004 | 01:46 PM
The original VQ...
Another kinda stuid question, can my 02 sensor be reading wrong because of my high flow cat, this is what my frined is tellin me but he has a honda so who knows. what do you guys think?
Old Jan 9, 2004 | 02:06 PM
Dave B's Avatar
Not DAVEB the parts guy
no i changed the right one, it did bang around on the floor alittle but i dont think it messed it up.
According to the Nissan FSM, if an 02 sensor is dropped from a height of over 8" (something like that), it's to be replaced. 02 sensors are very fragile.
Also, the knock sensor will NOT throw 02 sensor codes. Only failing 02 sensors throw o2 sensor and knock sensor codes. If the knock sensor code is thrown by itself, then it's a problem with the knock sensor or harness.
Dave
Old Jan 9, 2004 | 02:07 PM
Dave B's Avatar
Nope. I have a high flow cat (which does nothing) and my 7 year old OEM sensor reads just fine. Confirmed with my OBD Scan plotting software.
Dave
Old Jan 9, 2004 | 05:26 PM
The original VQ...
damm i think im gona buy another 02 sensor now cause of it banging around with my tools and on the floor.
The weird thing is i think i had the knock sensor code and then later got the 02 code. Im gona change the knock sensor sence i already bought it a while ago and see what happens.
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
