idle 500RPM??!!
idle 500RPM??!!
As of recent my car has started idleing at a low rpm gradually getting worse and with a low idle comes a vibration obviosly. Tonight my car was idleing at 500 rpm. I know this is not normal so how do i corect this. Also recently my gas milage had been very poor, is there a posibility that the two problems could be related such as a knock sensor, or o2 sensor? Please help! Thanks in advanced.
-Tom
-Tom
Originally Posted by SXN
i would suggest the knock sensor, atleast check it. If that isnt the problem, there is an idle adjustment cable, but dont mess with that unless you have to
Here is the link for how to change it (which means you could easily check it with the same set of instructions)
http://www.motorvate.ca/mvp.php/507
the knock sensor is a resistor/sensor, so to check it, you use a voltage meter that shows resistance. I am not sure on the exact ammount of resistance it should register, but check out the link, and see if it is something you are up to doing. Hopefully someone can help out with that number
get back to me, and let me know how it goes. Your car looks real good, strangely like mine. Take off your pin stripe and get some clear corners
Originally Posted by gto400no1
I actually do have clear corners, im just too lazy to get new pics... lol, also for a few weeks i had gen 2 altezzas and they look nice, but one was not working and had to send it back
oh well, to each his own
Originally Posted by Maxima99SEbose
Altezzas....
oh well, to each his ownThread
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
