Could my clutch be causing this problem? (semi-long)
OK, I'm really gonna change my name to post-*****. Anyway, I've been searching all day to track down this prob on the net and calling friends who have/do own 4th gens. Here is the problem:
I have a 1996 GLE with 112,000 miles on it. I just bought it a month ago and aside from a glitchy sensor which Jepht20 was kind enough to help me with, it had no immediate problems except that it jumped in and out of 4th gear going 40ish. I can live with that but here is the main problem. (Did this on my 3rd gen too till it ****ed up the tranny so bad I had to replace it. Partly my dad's fault.) When coming from a dead stop and shifting to 2nd gear it's pretty rough. It does it even after the engine and tranny are very warm. Also, when the tranny comes out of 4th gear like I was saying, it's pretty rough. Sometimes with an audible clunk. Shifting to 3rd gear and then to 4th are OK. I am going to do a valve body mod either was as I heard it helps your tranny a lot. Anybody who has had this prob or a clutch replaced please help! I'll do a write-up on it when I (hopefully) solve the problem. I know I'm a pain in the *** but I'll do some how-to's when I get done to make up for it
It's jerky. No grinding or struggling. I feel it release and the pop into second but it pops hard. Coming from 4th, it goes into 3rd again. I read the manual about this (turn off the o/d etc.) but again the problem is it's jerky going back into third. I have an automatic. EDIT: A more severe version of this problem blew my torque converter in the 3rd gen eventually. It was the TC according the the tranny shop anyway. They were a bunch of screw-ups though.
Originally Posted by helaesus2
Is it a "Take it to the dealer" pain or is it something I can blow a saturday on and fix?
Lol, even if you just need new break pads they'll tell you that you need a new tranny. I'm lucky though, I got a pretty honest dealer. I know a guy who works there too so i don't get hosed over too bad. Thanks for the help though, I'll go do some research and see what I find
hopefully I can fix it.
One more thing, sorry to double post, but my O/D light flashed at me like 8 times this morning. I forgot about it until now (you try to remember stuff that happened at 4:30 in the morning
), is that a dead giveaway or does the O/D light mean something is really hosed with my tranny. last question. promise.
ok, here is how to do it. It's on page 7B-2 in the hayes manual.
Warm up the engine to operating temp
Turn off the engine (wait 5 secs before proceeding.)
Turn engine to ACC
Put overdrive in "on"
Move shifter to P
Turn ignition to "on" but do not start engine.
OD off will come on for 2 seconds.
If it doesn't come on there's nothing wrong with the tranny.
Turn engine to OFF
Turn ignition ON but do not start
Move lever to D
Turn ignition OFF
Turn O/D off
Turn ignition to ON and move shifter to 2
Turn O/D on
Move Shifter to 1
Turn O/D off
Depress gas all the way to the floor and release
COmputer displays info VIA O/D light.
Codes to follow
It's like entering playstation cheats from hell.
Turn engine to ACC
Move shifter to P
Turn engine to OFF
Move lever to D
Turn ignition OFF
Turn O/D off
Turn O/D on
Move Shifter to 1
Turn O/D off
Codes to follow
"The computer for the automatic transacle has a self diagnostic capability; it continually monitors important information sensor and output actuator circuits for malfunctions. When a monitored circuit is damaged, shorted or disconnected, a diagnostic trouble code is stored in the computers memory. At a dealer service department, computer memory with a proprietary diagnostic instrument know as CONSULT. Codes can also be extracted with some generic scanners. However, neither the CONSULT nor scanners are generall available to the home mechanic, so the following procedure is provided to enable you to extract any stored codes by using the OD OFF indicator light on the insrument cluster"......
a. if the first ofd the ten-flash sequence is long, the revolution sensor circuit is shorted or disconnected
b. if the second of the ten flashes is long, the vehicle speed sensor circuit is shorted or disconnected
c. if the third flash is long, the throttle position sensor circuit is shorted or disconnected
d. if the fourth flash is long, the shift solenoid valve A circuit is shorted or disconnected
e. if the 5th is long, the shift solenoid valve B circuit is shorted or disconnected
f. if the 6th is long, the overrun clutch solenoid is shorted or disconnected
g. if the 7th flash is long, the torque converter clutch solenoid valve circuit is shorted or disconnected.
h. if the 8th flash is long, the fluid temperature sensor is disconnected or the computer power source circuit is damaged
i. if the 9th flash is long, the engine speed signal circuit is shorted or disconnected
j. if the 10th flash is long, the line pressure solenoid valve circuit is shorted or disconnected
k. if the OD OFF indicator light flashes on and off, alternating back and forth between long flashes, and long pauses, all of equal lenth, either the battery power is low, the battery has been disconnected for a long time, or the battery has been connected incorrectly.
l. 1998 and earlier models: if the OD OFF indicator light doesnt come back on, either the neutral start/back-up light switch, or the overdrive switch or the throttle position switch circuit is disconnected, or the computer is damaged.
m. in 1999 models: if the OD OFF indicator lightcomes on but doesnt flash, either the neutral start/back-up light switch, or the overdrive switch or the throttle position switch circuit is disconnected or the computer is damaged
except for the vehicle speed sensor and throttle position sensor, bothof which are covered in chap 6, reparing the rest of malfunctions is beyond the scope of the home mechanic. if one or more of thse codes is displayed, have the transaxle repaired by a dealer service dept. or automatic trans shop
Well, I'm off to diagnose. Thanks to all for helping. Looks like I'l probably be making a trip to Rob Doll Nissan tommorrow. Hope this doesn't cost me out the bum. Edit: It flashed a code 9. Speed sensor which I replaced yesterday. I guess I have to reset it. Now for a new knock sensor
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
ballerchris510
Sep 10, 2015 09:35 PM
