Air\Fuel ration gauge to ECU ??? anybod know...
Ok i just got my Air\fuel gauge and i need to hook it up to my ECU... 2 questions
1)Where is the ECU....?
2) and what wire (color) do i tap the ari\fual gauge into ??
or where can i found this out ???
thanx
thanx
http://www.fastmaxima.com/images/dia...AF%20Gauge.jpg
The above link is the pin diagram of the ECU(credit to Hal). You can tap into either of the highlighted pins to get a signal to your A/F guage.
The ECU is located under the center console, pretty much directly behind the ashtray on the floorboard where it rises in the middle. Remove the panel on the passenger side, unplug the clear plastic wiring harness and tap away.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
